Hello,
i want to write to the flash memory of mkrwan1310. somehow i haven't succeeded init. can you help me with any suggestion, the library i have to be using for this.
What did you do?
i tried to write a string into the memory. using the library, Arduino_mkrmem.
Post your code. Don't forget the code tags.
I asked you to use code tags. Please also explain, what happened? What went wrong, exactly?
Please read the forum guidelines that you were asked to read when you joined. I'm asking you to do this because I've asked you for two standard things that are outlined there:
-posting using code tags
-providing a clear, complete report of the symptoms of the problem
and you haven't done either one.
Ahh... i think i havent quite followed up the rules. sry for the mess. ill be back with straight things.
