You don’t need to worry about those lines unless you plan to use PJ2 as a pin change interrupt. However if you do, I have modified them for you:
#define digitalPinToPCICR(p) ( (((p) >= 10) && ((p) <= 13)) || \
(((p) >= 50) && ((p) <= 53)) || \
(((p) >= 62) && ((p) <= 69)) || \
((p) == 70) ? (&PCICR) : ((uint8_t *)0) )
#define digitalPinToPCICRbit(p) ( (((p) >= 10) && ((p) <= 13)) || (((p) >= 50) && ((p) <= 53)) ? 0 : \
( (((p) >= 62) && ((p) <= 69)) ? 2 : \
( ((p) == 70) ? 1 : 0 ) ) )
#define digitalPinToPCMSK(p) ( (((p) >= 10) && ((p) <= 13)) || (((p) >= 50) && ((p) <= 53)) ? (&PCMSK0) : \
( (((p) >= 62) && ((p) <= 69)) ? (&PCMSK2) : \
( ((p) == 70) ? (&PCMSK1) : ((uint8_t *)0) ) ) )
#define digitalPinToPCMSKbit(p) ( (((p) >= 10) && ((p) <= 13)) ? ((p) - 6) : \
( (((p) >= 50) && ((p) <= 53)) ? (53 - (p)) : \
( (((p) >= 62) && ((p) <= 69)) ? ((p) - 62) : \
( ((p) == 70) ? 3 : 0 ) ) ) )
In order to get a new pin to work, you need to do a several steps:
(1) at the end of this:
const uint8_t PROGMEM digital_pin_to_port_PGM[]
add this:
PJ , // PJ 2 ** 70 ** D70
This specifies which port the pin is on (in this case J)
(2) at the end of this:
const uint8_t PROGMEM digital_pin_to_bit_mask_PGM[]
add this:
_BV( 2 ) , // PJ 2 ** 70 ** D70
This specifies a bit mask for this pin in its port (In this case it is the bitmask for pin 2)
(3) at the end of this:
const uint8_t PROGMEM digital_pin_to_timer_PGM[]
add this:
NOT_ON_TIMER , // PJ 2 ** 70 ** D70
This specifies that it is not a PWM output (which it is not)
(4) at the to, change this:
#define NUM_DIGITAL_PINS 70
to this:
#define NUM_DIGITAL_PINS 71
This tells the IDE there are now 71 useable pins not 70.
Then restart the IDE and try to run the code. It should work.
