Hey folks.
I'm struggling to figure out how to display an accurate RPM reading with a hall effect sensor, for a project I've got going.
All of the examples I've seen, show the concept works, but readings tend to be all over the place (+/- 100 RPM) which is unusable to me.
I started by trying to modify this example code, which appears to be for RPM's up to 10,000, using one magnet.
RPM meter code (tested on device rotating at 10,000 rpm)
rev.001
* using a hall effect sensor
http://www.adafruit.com/index.php?main_page=product_info&cPath=35&products_id=158
* using a parallel LCD with
LiquidCrystal Library
http://www.ladyada.net/learn/lcd/charlcd.html
http://www.arduino.cc/en/Tutorial/LiquidCrystal
with pins 7,6,5,4,3,2
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(7,6,5,4,3,2);
// read the hall effect sensor on pin 2
const int hallPin=8;
const unsigned long sampleTime=1000;
const int maxRPM = 10200;
pinMode(hallPin,INPUT);
// set up the LCD's number of rows and columns:
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print("initializing");
lcd.clear();
int rpm=getRPM();
lcd.clear();
displayRPM(rpm);
displayBar(rpm);
int getRPM()
// sample for sampleTime in millisecs
int kount=0;
boolean kflag=LOW;
unsigned long currentTime=0;
unsigned long startTime=millis();
while (currentTime<=sampleTime)
if (digitalRead(hallPin)==HIGH)
kflag=HIGH;
if (digitalRead(hallPin)==LOW && kflag==HIGH)
kount++;
kflag=LOW;
currentTime=millis()-startTime;
int kount2rpm = int(60000./float(sampleTime))*kount;
return kount2rpm;
void displayRPM(int rpm)
lcd.clear();
// set the cursor to column 0, line 1
lcd.setCursor(0, 0);
// print the number of seconds since reset:
lcd.print(rpm,DEC);
lcd.setCursor(7,0);
lcd.print("RPM");
void displayBar(int rpm)
int numOfBars=map(rpm,0,maxRPM,0,15);
lcd.setCursor(0,1);
if (rpm!=0)
for (int i=0; i<=numOfBars; i++)
lcd.setCursor(i,1);
lcd.write(1023);
I've added 50 magnets, to a larger surface area (for a little more time between interrupts) and am trying to get accurate readings starting from around 400 RPM, to calculate the time it takes for a flywheel to free-spin down to around 50 RPM.
Am I on the right track with more interrupts per revolution?
Is float math the right way to go about this?
Would an optical sensor, with alternating white/black lines on the axle, be more accurate?
I haven't made much progress on this in the last couple weeks, and it's a little frustrating.
Could anyone point me in the right direction?
