#define CAYENNE_PRINT Serial
#include <CayenneMQTTYun.h> //MQTT Arduino Yun Library
/Hardware Related Macros************/
#define MG_PIN (A0) //define which analog input channel you are going to use
#define BOOL_PIN (2)
#define DC_GAIN (8.5) //define the DC gain of amplifier
/Software Related Macros*************/
#define READ_SAMPLE_INTERVAL (50) //define how many samples you are going to take in normal operation
#define READ_SAMPLE_TIMES (5) //define the time interval(in milisecond) between each samples in
//normal operation
/Application Related Macros************/
//These two values differ from sensor to sensor. user should derermine this value.
#define ZERO_POINT_VOLTAGE (0.220) //define the output of the sensor in volts when the concentration of CO2 is 400PPM
#define REACTION_VOLTGAE (0.030) //define the voltage drop of the sensor when move the sensor from air into 1000ppm CO2
/Globals******************/
float CO2Curve[3] = {2.602,ZERO_POINT_VOLTAGE,(REACTION_VOLTGAE/(2.602-3))};
//two points are taken from the curve.
//with these two points, a line is formed which is
//"approximately equivalent" to the original curve.
//data format:{ x, y, slope}; point1: (lg400, 0.324), point2: (lg4000, 0.280)
//slope = ( reaction voltage ) / (log400 –log1000)
//Username,password,clientID from Cayenne webpage
//Allow Arduino to communicate with Cayenne
char username[] = "65f0e750-503b-11e9-ad96-c15442ccb423";
char password[] = "a5110852eff8cb0c4b999b8b681fda94c67f6274";
char clientID[] = "84bf0640-5427-11e9-ba40-5d168a516101";
Serial.begin(115200); //set buad rate to 115200 to use MQTT communication
Cayenne.begin(username, password, clientID); //begin communication between Arduino and Cayenne
//CO2 sensor
pinMode(BOOL_PIN, INPUT); //set pin to input
digitalWrite(BOOL_PIN, HIGH); //turn on pullup resistors
Serial.print("MG-811 Demostration\n");
pinMode(13,OUTPUT);
void loop(){
Cayenne.loop();
int percentage;
float volts;
volts = MGRead(MG_PIN);
Serial.print( "SEN0159:" );
Serial.print(volts);
Serial.print( "V " );
percentage = MGGetPercentage(volts,CO2Curve);
Serial.print("CO2:");
if (percentage == -1) {
Serial.print( "<400" );
Serial.print(percentage);
Serial.print( "ppm" );
Serial.print("\n");
if( percentage > 1000.0 ) {
if( ledState ) {
ledState = true;
} else
ledState = false;
if (digitalRead(BOOL_PIN) ){
Serial.print( "=====BOOL is HIGH======" );
Serial.print( "=====BOOL is LOW======" );
Serial.print("\n");
Cayenne.virtualWrite(6,percentage, "co2", "ppm");
/***************************** MGRead *********************************************
Input: mg_pin - analog channel
Output: output of SEN-000007
Remarks: This function reads the output of SEN-000007
float MGRead(int mg_pin)
int i;
float v=0;
for (i=0;i<READ_SAMPLE_TIMES;i++) {
v += analogRead(mg_pin);
delay(READ_SAMPLE_INTERVAL);
v = (v/READ_SAMPLE_TIMES) *5/1024 ;
return v;
/***************************** MQGetPercentage **********************************
Input: volts - SEN-000007 output measured in volts
pcurve - pointer to the curve of the target gas
Output: ppm of the target gas
Remarks: By using the slope and a point of the line. The x(logarithmic value of ppm)
of the line could be derived if y(MG-811 output) is provided. As it is a
logarithmic coordinate, power of 10 is used to convert the result to non-logarithmic
value.
int MGGetPercentage(float volts, float *pcurve)
if ((volts/DC_GAIN )>=ZERO_POINT_VOLTAGE) {
return -1;
return pow(10, ((volts/DC_GAIN)-pcurve[1])/pcurve[2]+pcurve[0]);
How to make my led blink whenever the c02 value is above 1k
