How to add a ON timer
  switch (state1) {
    case 1:
      digitalWrite(OUTPUT1_PIN, LOW);
      if (digitalRead(SENSOR1_PIN) == HIGH ) transition1 = 12;
    case 2:
      if (millis() > time_to_switch_off_1 ) transition1 = 21;
      digitalWrite(OUTPUT1_PIN, HIGH);
  switch (transition1) {
    case 12:
      Serial.println("Sensors 1 AND 2 active: output 1 is ON");
      time_to_switch_off_1 = millis() + TIMER1 * 1000UL;
      transition1 = 0;
      state1 = 2;
    case 21:
      Serial.println("TIMER 1 has ended");
      if (digitalRead(SENSOR1_PIN) == HIGH ) {
        state1 = 2;
        Serial.println("Sensor 1 AND 2 still active, output 1 stays ON");
      else {
        state1 = 1;
        Serial.println("Sensor 1 OR 2 NOT active, output 1 OFF");
      transition1 = 0;
Thanks
What is an "ON timer" supposed to time?
Steve
#define OUTPUT1_PIN  8
#define OUTPUT2_PIN  9
#define OUTPUT3_PIN  10
#define OUTPUT4_PIN  11
#define OUTPUT5_PIN  12
#define OUTPUT6_PIN  13
#define OUTPUT7_PIN  A0
#define OUTPUT8_PIN  A1
#define OUTPUT9_PIN  A2
#define SENSOR1_PIN  2 // controls output1
#define SENSOR2_PIN  3
#define SENSOR3_PIN  4 // controls output1
#define SENSOR4_PIN  5
#define TIMER1        30 // [s]
#define TIMER2        33 // [s]
#define TIMER3        36 // [s]
#define TIMER4        39 // [s]
#define TIMER5        42 // [s]
#define TIMER6        45 // [s]
#define TIMER7        48 // [s]
#define TIMER8        51 // [s]
#define TIMER9        54 // [s]
#define TIMER_ONN_1   2  // [S]
#define TIMER_ONN_1   3
#define TIMER_ONN_1   4
#define TIMER_ONN_1   5
#define TIMER_ONN_1   6
#define TIMER_ONN_1   7
#define TIMER_ONN_1   8
#define TIMER_ONN_1   9
#define TIMER_ONN_1   10
byte state1 = 1, transition1;
byte state2 = 1, transition2;
byte state3 = 1, transition3;
byte state4 = 1, transition4;
byte state5 = 1, transition5;
byte state6 = 1, transition6;
byte state7 = 1, transition7;
byte state8 = 1, transition8;
byte state9 = 1, transition9;
unsigned long time_to_switch_off_1;
unsigned long time_to_switch_off_2;
unsigned long time_to_switch_off_3;
unsigned long time_to_switch_off_4;
unsigned long time_to_switch_off_5;
unsigned long time_to_switch_off_6;
unsigned long time_to_switch_off_7;
unsigned long time_to_switch_off_8;
unsigned long time_to_switch_off_9;
  pinMode(SENSOR1_PIN, INPUT);
  pinMode(SENSOR2_PIN, INPUT);
  pinMode(SENSOR3_PIN, INPUT);
  pinMode(SENSOR4_PIN, INPUT);
  pinMode(OUTPUT1_PIN, OUTPUT);
  pinMode(OUTPUT2_PIN, OUTPUT);
  pinMode(OUTPUT3_PIN, OUTPUT);
  pinMode(OUTPUT4_PIN, OUTPUT);
  pinMode(OUTPUT5_PIN, OUTPUT);
  pinMode(OUTPUT6_PIN, OUTPUT);
  pinMode(OUTPUT7_PIN, OUTPUT);
  pinMode(OUTPUT8_PIN, OUTPUT);
  pinMode(OUTPUT9_PIN, OUTPUT);
  Serial.println("Ready, waiting for sensors");
  // OUT1, SENSOR1
  switch (state1) {
    case 1:
      if ((digitalRead(SENSOR1_PIN)) && (digitalRead(SENSOR2_PIN)) || (digitalRead(SENSOR3_PIN)) && (digitalRead(SENSOR4_PIN))) transition1 = 12;
    case 2:
    case 12:
      transition1 = 0;
      state1 = 2;
    case 21:
      if ((digitalRead(SENSOR1_PIN)) && (digitalRead(SENSOR2_PIN)) || (digitalRead(SENSOR3_PIN)) && (digitalRead(SENSOR4_PIN))) {
        state1 = 2;
      else {
        state1 = 1;
      transition1 = 0;
  // OUT 2, SENSOR1
  switch (state2) {
    case 1:
      digitalWrite(OUTPUT2_PIN, LOW);
      if ((digitalRead(SENSOR1_PIN)) && (digitalRead(SENSOR2_PIN)) || (digitalRead(SENSOR3_PIN)) && (digitalRead(SENSOR4_PIN))) transition2 = 12;
    case 2:
      digitalWrite(OUTPUT2_PIN, HIGH);
      if (millis() > time_to_switch_off_2) transition2 = 21;
  switch (transition2) {
    case 12:
      Serial.println("Sensors 1 AND 2 active: output 2 is ON");
      time_to_switch_off_2 = millis() + TIMER2 * 1000UL;
      transition2 = 0;
      state2 = 2;
    case 21:
      Serial.println("TIMER 2 has ended");
        state2 = 2;
        Serial.println("Sensor 1 AND 2 still active, output 2 stays ON");
      else {
        state2 = 1;
        Serial.println("Sensor 1 OR 2 NOT active, output 2 OFF");
      transition2 = 0;
  // OUT3 SENSOR1
  switch (state3) {
    case 1:
      digitalWrite(OUTPUT3_PIN, LOW);
      if ((digitalRead(SENSOR1_PIN)) && (digitalRead(SENSOR2_PIN)) || (digitalRead(SENSOR3_PIN)) && (digitalRead(SENSOR4_PIN))) transition3 = 12;
    case 2:
      digitalWrite(OUTPUT3_PIN, HIGH);
      if (millis() > time_to_switch_off_3) transition3 = 21;
  switch (transition3) {
    case 12:
      Serial.println("Sensors 1 AND 2 active: output 3 is ON");
      time_to_switch_off_3 = millis() + TIMER3 * 1000UL;
      transition3 = 0;
      state3 = 2;
    case 21:
      Serial.println("TIMER 3 has ended");
        state3 = 2;
        Serial.println("Sensor 1 AND 2 still active, output 3 stays ON");
      else {
        state3 = 1;
        Serial.println("Sensor 1 OR 2 NOT active, output 3 OFF");
      transition3 = 0;
how to add ON TIMER in each output same like OFF TIMER
The OFF TIMERs appear to cause the outputs to go HIGH after a period of time has passed since they went LOW as a result of readings from some sensors. Please explain what the ON TIMERs should do ?
at present, buttons active , all outputs active same time and off with timer,
i need to modify, when buttons active each outputs active one by one
bijitha:
I am sorry but I still don't understand what you want to do. Perhaps somebody else will, or maybe you could explain in more detail.
I think that there may be a language problem. What is your native language ?
delayed action in each output
bijitha:
I think that you mean you would like the outputs to go LOW based on the readings from the sensors but only after a period of time has elapsed. Is that correct ?
If so, then what should happen if the input from the sensor changes during the wait period ?
  // OUT1, SENSOR1
  switch (state1) {
    case 1:
    case 2:
delay(1000);  // HER I NEED millis() FUNCTION
    case 12:
      transition1 = 0;
      state1 = 2;
    case 21:
        state1 = 2;
      else {
        state1 = 1;
      transition1 = 0;
Another all are ok
