how to add a second 7 segment display using a 74HC595
Hi all,
I have create a Up & Down counter with one 7 segment display using the 74HC595.
The code (below) works fine with the 74HC595, but it count only from 0 till 9
I need some help to add a second 7 segment display so i can count from 0 till 99
this is the code for one 7 segment display
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);               // I2C initialize the library with the numbers of the interface pins
byte Up_Button = 2;                                                          // Up button to digital input pin 2 (see diagram how to connect!!)
byte Down_Button = 3;                                                        // Down button to digital input pin 3 (see diagram how to connect!!)
int speed = 1000;                                                            // used to control speed of counting
                                 //Global variables
int Up_State = 0;                                                            // variable that will read the Up button (either HIGH or LOW)
int Down_State = 0;                                                          // variable that will read the Down button (either HIGH or LOW)
int counter = 0;                                                             // variable that will store the count
int last_Up_State = 0;
int last_Down_State = 0;
const int latchPin = 5;                                                      // Pin connected to Pin 12 of 74HC595 (Latch)
const int dataPin  = 6;                                                      // Pin connected to Pin 14 of 74HC595 (Data)
const int clockPin = 7;                                                      // Pin connected to Pin 11 of 74HC595 (Clock)
unsigned long t1;
unsigned long t2;
const byte numbers[10] = {
  0b11111100,  // 0
  0b01100000,  // 1
  0b11011010,  // 2
  0b11110010,  // 3
  0b01100110,  // 4
  0b10110110,  // 5
  0b10111110,  // 6
  0b11100000,  // 7
  0b11111110,  // 8
  0b11100110,  // 9
  pinMode(Up_Button, INPUT);                                                 // set Up Button as INPUT
  pinMode(Down_Button, INPUT);                                               // set Down Button as INPUT
    t1 = millis();
  pinMode(latchPin, OUTPUT);                                                 // set pins to output
  pinMode(clockPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  lcd.begin(16, 2);                                                          // set up the LCD's number of columns and rows:
  lcd.print("     V1.0 ");                                             // print a info message on the LCD
  t2 = millis();                                                             // update digit every second
  if(t2 - t1 > 1000)
    //      counter++;                                                       // automatic counting UP 7 segment display test
    t1 = t2;
    if(counter > 9) {
      counter = 0;
  show(numbers[counter]);
void show( byte number)
  for(int j=0; j<=7; j++)                                                    // Loop over each segment in the "number" we're about to display, and illuminate only one segment at a time.
    byte toWrite = number & (0b10000000 >> j);
    if(!toWrite) {
      continue;
    }        // If all bits are 0 then no point writing it to the shift register, so break out and move on to next segment.
    shiftIt(toWrite);                                                        // Otherwise shift it into the register
void shiftIt (byte data)
  digitalWrite(latchPin, LOW);                                               // Set latchPin LOW while and clock these 8 bits in to the register to illuminate a single segment.
  for (int k=0; k<=7; k++)
    digitalWrite(clockPin, LOW);                                             // clockPin LOW prior to sending bit
    if ( data & (1 << k) )                                                   // Do another bitwise AND against a mask to check the state of each bit as we clock it in.
      digitalWrite(dataPin, LOW);                                            // turn "On"
      digitalWrite(dataPin, HIGH);                                           // turn "Off"
    digitalWrite(clockPin, HIGH);                                            // and clock the bit in
  digitalWrite(clockPin, LOW);                                               //stop shifting out data
  digitalWrite(latchPin, HIGH);                                              //set latchPin to high to lock and send data
  //    delay(100);                                                           // put delay here to check the multiplexing in action!
  Up_State = digitalRead(Up_Button);                                         // read the Up button state
  Down_State = digitalRead(Down_Button);                                     // read the Down button state
  if(Up_State != last_Up_State)                                              // compare Up button state to its last state
    if(Up_State == LOW)                                                      // Up button is pressed
      counter = counter++;                                                   // increment the counter
      lcd.setCursor(0, 1);
      lcd.print("count: ");
      lcd.setCursor(7, 1);
      lcd.print(counter);                                                    // print it on LCD
      lcd.print("   ");                                                      // 3 blank spaces
      delay(speed);                                                          // debounce delay
  last_Up_State = Up_State;
  if(Down_State != last_Down_State)                                          // compare Down state to its lastState
    if(Down_State == LOW)                                                    // Down button is pressed
      counter = counter--;                                                   // decrement the counter
  last_Down_State = Down_State;
You can daisy-chain the two shift registers. They share the Clock and Latch pins and the Data Out of the first connects to the Data In of the second. You pull the Latch line low as before and then shiftOut() two times. The second shiftOut() pushes the first byte into the second shift register.
Example here:
http://www.gammon.com.au/forum/?id=11518
