Could someone please help me work out how to add a timeout to the Garage Parking Assistant code by user Bcjams.
Another user added a timeout to the code but fundamentally changed it at the same time. The project doesn't react the same. I'm looking to keep the exact same functionality as the code below, but hopefully introduce a timeout that turns the leds off after 60 seconds if no further movement is picked up by the sensor (the car is parked). Sometimes we have the garage open for an hour or two, so it would be nice to not have the leds on the entire time the garage door is open.
Any help on the coding front would be most appreciated
* Garage Parking Sensor - Published By Bob Torrence
#include <FastLED.h>
#include <QuickStats.h>
QuickStats stats; //initialize an instance of this class
// defining the pins
#define LED_PIN 7
#define NUM_LEDS 15
const int trigPin = 9;
const int echoPin = 10;
// defining variables
CRGB leds[NUM_LEDS];
float duration;
float durationarray[15];
int distance;
int stopdistance=115; //parking position from sensor (CENTIMETERS)
int startdistance=400; //distance from sensor to begin scan as car pulls in(CENTIMETERS)
int increment=((startdistance-stopdistance)/15);
pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
pinMode(echoPin, INPUT); // Sets the echoPin as an Input
FastLED.addLeds<WS2812, LED_PIN, GRB>(leds, NUM_LEDS);
Serial.begin(9600); // Starts the serial communication
for (int i=0;i<=14;i++){
// Clears the trigPin
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
// Sets the trigPin on HIGH state for 10 micro seconds
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Reads the echoPin, returns the sound wave travel time in microseconds
durationarray[i] = pulseIn(echoPin, HIGH);
distance= durationarray[i]*0.034/2;
Serial.print(distance);
Serial.print(" ");
duration = (stats.median(durationarray,15));
// Calculating the distance
distance= duration*0.034/2;
// Prints the distance on the Serial Monitor
Serial.print("Distance: ");
Serial.println(distance);
if (distance<stopdistance){
for (int i = 0; i <= 14; i++) {
leds[i] = CRGB ( 255, 0, 0);
FastLED.show();
if (distance<stopdistance+increment){
for (int i = 1; i <= 14; i++) {
leds[i] = CRGB ( 0, 0, 0);
for (int i = 0; i <= 0; i++) {
leds[i] = CRGB ( 255, 255, 0);
FastLED.show();
delay(50);
if (distance<stopdistance+increment*2){
for (int i = 2; i <= 14; i++) {
for (int i = 0; i <= 1; i++) {
FastLED.show();
delay(50);
if (distance<stopdistance+increment*3){
for (int i = 3; i <= 14; i++) {
for (int i = 0; i <= 2; i++) {
FastLED.show();
delay(50);
if (distance<stopdistance+increment*4){
for (int i = 4; i <= 14; i++) {
for (int i = 0; i <= 3; i++) {
leds[i] = CRGB ( 0, 255,0);
FastLED.show();
delay(50);
if (distance<stopdistance+increment*5){
for (int i = 5; i <= 14; i++) {
for (int i = 0; i <= 4; i++) {
FastLED.show();
delay(50);
if (distance<stopdistance+increment*6){
for (int i = 6; i <= 14; i++) {
for (int i = 0; i <= 5; i++) {
FastLED.show();
delay(50);
if (distance<stopdistance+increment*7){
for (int i = 7; i <= 14; i++) {
for (int i = 0; i <= 6; i++) {
FastLED.show();
delay(50);
if (distance<stopdistance+increment*8){
for (int i = 8; i <= 14; i++) {
for (int i = 0; i <= 7; i++) {
FastLED.show();
delay(50);
if (distance<stopdistance+increment*9){
for (int i = 9; i <= 14; i++) {
for (int i = 0; i <= 8; i++) {
FastLED.show();
delay(50);
if (distance<stopdistance+increment*10){
for (int i = 10; i <= 14; i++) {
for (int i = 0; i <= 9; i++) {
FastLED.show();
delay(50);
if (distance<stopdistance+increment*11){
for (int i = 11; i <= 14; i++) {
for (int i = 0; i <= 10; i++) {
FastLED.show();
delay(50);
if (distance<stopdistance+increment*12){
for (int i = 12; i <= 14; i++) {
for (int i = 0; i <= 11; i++) {
FastLED.show();
delay(50);
if (distance<stopdistance+increment*13){
for (int i = 13; i <= 14; i++) {
for (int i = 0; i <= 12; i++) {
FastLED.show();
delay(50);
if (distance<stopdistance+increment*14){
for (int i = 14; i <= 14; i++) {
for (int i = 0; i <= 13; i++) {
FastLED.show();
delay(50);
if (distance>=stopdistance+increment*14){
FastLED.show();
delay(50);
