How to add analogRead () to our own written library
Hello!
I tried to make a library for analog inputs, but it doesn’t work for me.
Can you help me with some advice? Thanks!
Analog.cpp
#include "Analog.h"
AI::AI(byte pin) {
  this->pin = pin;
  init();
void AI::init() {
	analogRead(pin);
Analog.h
#ifndef Analog_H
#define Analog_H
#include <Arduino.h>
// A N A L O G  I N P U T
class AI {
	private:
	byte pin;
	public:
	AI(byte pin);
	void init();
#endif
Please provide a detailed description of what you mean by "it doesn't work".
I tried this example:
#include <Analog.h>
#define Ana1 0
AI ai1(Ana1);
int val = 0;
  val = ai1; // <- Error
  Serial.println(val);
  Serial.println(' ');
Error:
exit status 1
cannot convert ‘AI’ to ‘int’ in assignment
To start with, a function named init() that reads a pin makes no sense
Try this
The .h
#ifndef Analog_H
#define Analog_H
class AI
  private:
    byte _pin;
  public:
    AI::AI(byte pin);  //constructor
    int read();  //read and return analogue value
#endif
The .cpp
#include "Analog.h"
AI::AI(byte pin)
  _pin = pin;
int AI::read()
  return analogRead(_pin);
Test sketch
#include "Analog.h"
AI ax(7);
  while (!Serial);
  Serial.println(ax.read());
Thanks UKHeliBob for the first step!
The library is functional, but the reading code has a problem. It only shows me the maximum value:
1023
1023
1023
Post a full example that illustrates the problem
This is the code:
#include "Analog.h"
AI ax(0);
  while (!Serial);
And this is the result in the simulator:
Did you use the .h and .cpp files exactly as I posted them ?
I know that my example works with real hardware
What does the emulator show if you print the raw value read from A0 without involving the library ?
I used your library:
And if I use a fixed value, it shows me that variable:
#include "Analog.h"
AI ax(0);
int val = 10;
  while (!Serial);
  //val = ax.read();
display:
10
10
10
It works. I had to put the NANO module to GND.
Thank you very much UKHeliBob !
that should be no surprise
What I had in mind was
Serial.println(analogRead(0));
