How to add custom modes to the "class NeoPatterns : public Adafruit_NeoPixel" class[solved]
I am new to the Adafruit NeoPixel library and have a question about the “class NeoPatterns : public Adafruit_NeoPixel” class. Up to now I have just used the FastLED library and I don’t have any experience with C++ classes (I just programmed with python) .
I am using the latest version of the NeoPixel library and I got most of the code from this tutorial
(I just removed the button code and added a serial connection to a python skript).
So my class looks like:
// Pattern types supported:
enum  pattern { NONE, Off, RAINBOW_CYCLE, THEATER_CHASE, COLOR_WIPE, SCANNER, FADE };
// Patern directions supported:
enum  direction { FORWARD, REVERSE };
// NeoPattern Class - derived from the Adafruit_NeoPixel class
    public:
    // Member Variables:
    pattern  ActivePattern;  // which pattern is running
    direction Direction;     // direction to run the pattern
    unsigned long Interval;   // milliseconds between updates
    unsigned long lastUpdate; // last update of position
    uint32_t Color1, Color2;  // What colors are in use
    uint16_t TotalSteps;  // total number of steps in the pattern
    uint16_t Index;  // current step within the pattern
    void (*OnComplete)();  // Callback on completion of pattern
    // Constructor - calls base-class constructor to initialize strip
    NeoPatterns(uint16_t pixels, uint8_t pin, uint8_t type, void (*callback)())
    :Adafruit_NeoPixel(pixels, pin, type)
        OnComplete = callback;
    // Update the pattern
    void Update()
        if((millis() - lastUpdate) > Interval) // time to update
            lastUpdate = millis();
            switch(ActivePattern)
                case RAINBOW_CYCLE:
                    RainbowCycleUpdate();
                case THEATER_CHASE:
                    TheaterChaseUpdate();
                case COLOR_WIPE:
                    ColorWipeUpdate();
                case SCANNER:
                    ScannerUpdate();
                case FADE:
                    FadeUpdate();
                default:
    // Increment the Index and reset at the end
    void Increment()
        if (Direction == FORWARD)
           Index++;
           if (Index >= TotalSteps)
                Index = 0;
                if (OnComplete != NULL)
                    OnComplete(); // call the comlpetion callback
        else // Direction == REVERSE
            --Index;
            if (Index <= 0)
                Index = TotalSteps-1;
    // Reverse pattern direction
    void Reverse()
            Direction = REVERSE;
            Direction = FORWARD;
            Index = 0;
    // Initialize for a RainbowCycle
    void RainbowCycle(uint8_t interval, direction dir = FORWARD)
        ActivePattern = RAINBOW_CYCLE;
        Interval = interval;
        TotalSteps = 255;
        Index = 0;
        Direction = dir;
    // Update the Rainbow Cycle Pattern
    void RainbowCycleUpdate()
        for(int i=0; i< numPixels(); i++)
            setPixelColor(i, Wheel(((i * 256 / numPixels()) + Index) & 255));
        show();
        Increment();
(I have also added some other effects like the mentioned tutorial)
I have 3 LED strips added:
NeoPatterns Strip2(9, 5, NEO_GRB + NEO_KHZ800, &Strip2Complete);
NeoPatterns Strip3(9, 6, NEO_GRB + NEO_KHZ800, &Strip3Complete);
NeoPatterns Strip1(24, 3, NEO_GRB + NEO_KHZ800, &Strip1Complete);
And change the colors with this main loop:
  Strip1.Update();
  Strip2.Update();
  Strip3.Update();
  if (Serial.available() > 0)
    achievedata();
  if (current_strip == 0)
      if (mode == "1"){
        Strip1.ActivePattern = RAINBOW_CYCLE;
        Strip1.TotalSteps = 255;
        Strip1.Interval = min(10, Strip3.Interval);
      else if (mode == "2"){
        Strip1.ActivePattern = THEATER_CHASE;
        Strip1.Interval = 100;
      else if (mode == "3"){
        Strip1.ActivePattern = COLOR_WIPE;
        Strip1.TotalSteps = Strip3.numPixels();
      else if (mode == "4"){
        Strip1.ActivePattern = SCANNER;
      else if (mode == "5"){
        Strip1.ActivePattern = FADE;
        Strip1.Interval = 20;
      Strip1.show();
    else if (current_strip == 1)
      if (mode == "1"){
        Strip2.ActivePattern = RAINBOW_CYCLE;
        Strip2.TotalSteps = 255;
        Strip2.Interval = min(10, Strip3.Interval);
        Strip2.ActivePattern = THEATER_CHASE;
        Strip2.Interval = 100;
        Strip2.ActivePattern = COLOR_WIPE;
        Strip2.TotalSteps = Strip3.numPixels();
        Strip2.ActivePattern = SCANNER;
        Strip2.ActivePattern = FADE;
        Strip2.Interval = 20;
      Strip2.show();
    else if (current_strip == 2)
      if (mode == "1"){
        Strip3.ActivePattern = RAINBOW_CYCLE;
        Strip3.TotalSteps = 255;
        Strip3.Interval = min(10, Strip3.Interval);
        Strip3.ActivePattern = THEATER_CHASE;
        Strip3.Interval = 100;
        Strip3.ActivePattern = COLOR_WIPE;
        Strip3.TotalSteps = Strip3.numPixels();
        Strip3.ActivePattern = SCANNER;
        Strip3.ActivePattern = FADE;
        Strip3.Interval = 20;
      Strip3.show();
  else // Back to normal operation
    // Restore all pattern parameters to normal values
(the variables “mode” and “current_strip” are from the function “achievedata”, which gets data from my python script)
But now my question: How can I add other modes (e.g. all LED’s off or in one color…) - and is it possible to add those to my class or do I need to solve my problem with an other class or function?
Thank you for your help :grinning:
Ok, I finally got it, it was easier than expected, I just added a custom function with an update function, and had to change some variables.
Changed lines:
enum  pattern { NONE, RAINBOW_CYCLE, THEATER_CHASE, COLOR_WIPE, SCANNER, FADE, STATIC };
case STATIC:  // Custom animation for candle
                    StaticUpdate();
void Static(uint16_t steps, uint8_t interval, direction dir = FORWARD)
      ActivePattern = OFF;
      TotalSteps = numPixels();
      Index = 0;
      Direction = dir;
    // Initialize for a OFF
    void StaticUpdate()
      for (int i = 0; i < numPixels(); i++)
          ColorSet(Color(red, green, blue));
        show();
        Increment();
else if (mode == "1"){
        Strip1.ActivePattern = STATIC;
        Strip1.TotalSteps = Strip1.numPixels();
Or try this library GitHub - ArminJo/NeoPatterns: Patterns for NeoPixel strips and matrixes including the patterns of the NeoPattern Example by Adafruit. :slight_smile:
