How to add date and time display on esp32 webserver code
So this is my current HTML code and I want to add a date and time display on the webserver how do i add it to my html code?
String SendHTML(float cap, float health, float cou, float temp, float hum, float heat, float volt, float amp, float smoke) {
  String ptr = "<!DOCTYPE html>";
  ptr += "<html>";
  ptr += "<head>";
  ptr += "<title>NP Robot BMS</title>";
  ptr += "<meta name='viewport' content='width=device-width, initial-scale=1.0'>";
  ptr += "<link href='https://fonts.googleapis.com/css?family=Open+Sans:300,400,600' rel='stylesheet'>";
  ptr += "<style>";
  ptr += "html { font-family: 'Open Sans', sans-serif; display: block; margin: 0px auto; text-align: center;color: #444444;}";
  ptr += "body{margin: 0px;} ";
  ptr += "h1 {margin: 50px auto 30px;} ";
  ptr += ".side-by-side{display: table-cell;vertical-align: middle;position: relative;}";
  ptr += ".text{font-weight: 600;font-size: 19px;width: 200px;}";
  ptr += ".reading{font-weight: 300;font-size: 50px;padding-right: 25px;}";
  ptr += ".cap .reading{color: #955BA5;}";
  ptr += ".health .reading{color: #955BA5;}";
  ptr += ".cou .reading{color: #955BA5;}";
  ptr += ".temp .reading{color: #F29C1F;}";
  ptr += ".hum .reading{color: #3B97D3;}";
  ptr += ".heat .reading{color: #F29C1F;}";
  ptr += ".volt .reading{color: #26B99A;}";
  ptr += ".amp .reading{color: #26B99A;}";
  ptr += ".smoke .reading{color: #26B99A;}";
  ptr += ".superscript{font-size: 17px;font-weight: 600;position: absolute;top: 10px;}";
  ptr += ".data{padding: 10px;}";
  ptr += ".container{display: table;margin: 0 auto;}";
  ptr += ".icon{width:65px}";
  ptr += "</style>";
  ptr += "<script>\n";
  ptr += "setInterval(loadDoc,1000);\n";
  ptr += "function loadDoc() {\n";
  ptr += "var xhttp = new XMLHttpRequest();\n";
  ptr += "xhttp.onreadystatechange = function() {\n";
  ptr += "if (this.readyState == 4 && this.status == 200) {\n";
  ptr += "document.body.innerHTML =this.responseText}\n";
  ptr += "};\n";
  ptr += "xhttp.open(\"GET\", \"/\", true);\n";
  ptr += "xhttp.send();\n";
  ptr += "}\n";
  ptr += "</script>\n";
  ptr += "</head>";
  ptr += "<body>";
  ptr += "<h1>NP Robot BMS</h1>";
  ptr += "<div class='container'>";
  ptr += "<div class='data cap'>";
  ptr += "<div class='side-by-side icon'>";
  ptr += "<svg enable-background='new 0 0 58.422 40.639'height=40.639px id=Layer_1 version=1.1 viewBox='0 0 58.422 40.639'width=58.422px x=0px xml:space=preserve xmlns=http://www.w3.org/2000/svg xmlns:xlink=http://www.w3.org/1999/xlink y=0px><g><path d='M58.203,37.754l0.007-0.004L42.09,9.935l-0.001,0.001c-0.356-0.543-0.969-0.902-1.667-0.902";
  ptr += "c-0.655,0-1.231,0.32-1.595,0.808l-0.011-0.007l-0.039,0.067c-0.021,0.03-0.035,0.063-0.054,0.094L22.78,37.692l0.008,0.004";
  ptr += "c-0.149,0.28-0.242,0.594-0.242,0.934c0,1.102,0.894,1.995,1.994,1.995v0.015h31.888c1.101,0,1.994-0.893,1.994-1.994";
  ptr += "C58.422,38.323,58.339,38.024,58.203,37.754z'fill=#955BA5 /><path d='M19.704,38.674l-0.013-0.004l13.544-23.522L25.13,1.156l-0.002,0.001C24.671,0.459,23.885,0,22.985,0";
  ptr += "c-0.84,0-1.582,0.41-2.051,1.038l-0.016-0.01L20.87,1.114c-0.025,0.039-0.046,0.082-0.068,0.124L0.299,36.851l0.013,0.004";
  ptr += "C0.117,37.215,0,37.62,0,38.059c0,1.412,1.147,2.565,2.565,2.565v0.015h16.989c-0.091-0.256-0.149-0.526-0.149-0.813";
  ptr += "C19.405,39.407,19.518,39.019,19.704,38.674z'fill=#955BA5 /></g></svg>";
  ptr += "</div>";
  ptr += "<div class='side-by-side text'>SOC</div>";
  ptr += "<div class='side-by-side reading'>";
  ptr += (int)cap;
  ptr += "<span class='superscript'>%</span></div>";
  ptr += "</div>";
  ptr += "<div class='data health'>";
  ptr += "</div>";
  ptr += "<div class='side-by-side text'>SOH</div>";
  ptr += (int)health;
  ptr += "</div>";
  ptr += "<div class='data cou'>";
  ptr += "</div>";
  ptr += "<div class='side-by-side text'>Count</div>";
  ptr += (int)cap;
  ptr += "<span class='superscript'>cycle</span></div>";
  ptr += "</div>";
  ptr += "<div class='data temp'>";
  ptr += "<svg enable-background='new 0 0 19.438 54.003'height=54.003px id=Layer_1 version=1.1 viewBox='0 0 19.438 54.003'width=19.438px x=0px xml:space=preserve xmlns=http://www.w3.org/2000/svg xmlns:xlink=http://www.w3.org/1999/xlink y=0px><g><path d='M11.976,8.82v-2h4.084V6.063C16.06,2.715,13.345,0,9.996,0H9.313C5.965,0,3.252,2.715,3.252,6.063v30.982";
  ptr += "C1.261,38.825,0,41.403,0,44.286c0,5.367,4.351,9.718,9.719,9.718c5.368,0,9.719-4.351,9.719-9.718";
  ptr += "c0-2.943-1.312-5.574-3.378-7.355V18.436h-3.914v-2h3.914v-2.808h-4.084v-2h4.084V8.82H11.976z M15.302,44.833";
  ptr += "c0,3.083-2.5,5.583-5.583,5.583s-5.583-2.5-5.583-5.583c0-2.279,1.368-4.236,3.326-5.104V24.257C7.462,23.01,8.472,22,9.719,22";
  ptr += "s2.257,1.01,2.257,2.257V39.73C13.934,40.597,15.302,42.554,15.302,44.833z'fill=#F29C21 /></g></svg>";
  ptr += "</div>";
  ptr += "<div class='side-by-side text'>Temperature</div>";
  ptr += (int)temp;
  ptr += "<span class='superscript'>&deg;C</span></div>";
  ptr += "</div>";
  ptr += "<div class='data hum'>";
  ptr += "<svg enable-background='new 0 0 29.235 40.64'height=40.64px id=Layer_1 version=1.1 viewBox='0 0 29.235 40.64'width=29.235px x=0px xml:space=preserve xmlns=http://www.w3.org/2000/svg xmlns:xlink=http://www.w3.org/1999/xlink y=0px><path d='M14.618,0C14.618,0,0,17.95,0,26.022C0,34.096,6.544,40.64,14.618,40.64s14.617-6.544,14.617-14.617";
  ptr += "C29.235,17.95,14.618,0,14.618,0z M13.667,37.135c-5.604,0-10.162-4.56-10.162-10.162c0-0.787,0.638-1.426,1.426-1.426";
  ptr += "c0.787,0,1.425,0.639,1.425,1.426c0,4.031,3.28,7.312,7.311,7.312c0.787,0,1.425,0.638,1.425,1.425";
  ptr += "C15.093,36.497,14.455,37.135,13.667,37.135z'fill=#3C97D3 /></svg>";
  ptr += "</div>";
  ptr += "<div class='side-by-side text'>Humidity</div>";
  ptr += (int)hum;
  ptr += "</div>";
  ptr += "<div class='data heat'>";
  ptr += "</div>";
  ptr += "<div class='side-by-side text'>Heat Index</div>";
  ptr += (int)heat;
  ptr += "</div>";
  ptr += "<div class='data volt'>";
  ptr += "<svg enable-background='new 0 0 40.542 40.541'height=40.541px id=Layer_1 version=1.1 viewBox='0 0 40.542 40.541'width=40.542px x=0px xml:space=preserve xmlns=http://www.w3.org/2000/svg xmlns:xlink=http://www.w3.org/1999/xlink y=0px><g><path d='M34.313,20.271c0-0.552,0.447-1,1-1h5.178c-0.236-4.841-2.163-9.228-5.214-12.593l-3.425,3.424";
  ptr += "c-0.195,0.195-0.451,0.293-0.707,0.293s-0.512-0.098-0.707-0.293c-0.391-0.391-0.391-1.023,0-1.414l3.425-3.424";
  ptr += "c-3.375-3.059-7.776-4.987-12.634-5.215c0.015,0.067,0.041,0.13,0.041,0.202v4.687c0,0.552-0.447,1-1,1s-1-0.448-1-1V0.25";
  ptr += "c0-0.071,0.026-0.134,0.041-0.202C14.39,0.279,9.936,2.256,6.544,5.385l3.576,3.577c0.391,0.391,0.391,1.024,0,1.414";
  ptr += "c-0.195,0.195-0.451,0.293-0.707,0.293s-0.512-0.098-0.707-0.293L5.142,6.812c-2.98,3.348-4.858,7.682-5.092,12.459h4.804";
  ptr += "c0.552,0,1,0.448,1,1s-0.448,1-1,1H0.05c0.525,10.728,9.362,19.271,20.22,19.271c10.857,0,19.696-8.543,20.22-19.271h-5.178";
  ptr += "C34.76,21.271,34.313,20.823,34.313,20.271z M23.084,22.037c-0.559,1.561-2.274,2.372-3.833,1.814";
  ptr += "c-1.561-0.557-2.373-2.272-1.815-3.833c0.372-1.041,1.263-1.737,2.277-1.928L25.2,7.202L22.497,19.05";
  ptr += "C23.196,19.843,23.464,20.973,23.084,22.037z'fill=#26B999 /></g></svg>";
  ptr += "</div>";
  ptr += "<div class='side-by-side text'>Voltage</div>";
  ptr += (int)volt;
  ptr += "<span class='superscript'>V</span></div>";
  ptr += "</div>";
  ptr += "<div class='data amp'>";
  ptr += "</div>";
  ptr += "<div class='side-by-side text'>Current</div>";
  ptr += (int)amp;
  ptr += "<span class='superscript'>A</span></div>";
  ptr += "</div>";
  ptr += "<div class='data smoke'>";
  ptr += "</div>";
  ptr += "<div class='side-by-side text'>Smoke</div>";
  ptr += (int)smoke;
  ptr += "<span class='superscript'>value</span></div>";
  ptr += "</div>";
  ptr += "</div>";
  ptr += "</body>";
  ptr += "</html>";
  return ptr;
This is my full code
#include <EEPROM.h>
#define EEPROM_SIZE 12
#include <WiFi.h>
#include <WebServer.h>
#include <time.h>
#include <Wire.h>
#include "cactus_io_HIH6130.h"
const char* ssid = "ssid";
const char* password =  "pass";
const char* resource1 = "/trigger/BMS_hih6130/with/key/asdds";
const char* server1 = "maker.ifttt.com";
const char* resource2 = "/trigger/BMS_sensors/with/key/asdds";
const char* server2 = "maker.ifttt.com";
const char* resource3 = "/trigger/BMS_health/with/key/asdds";
const char* server3 = "maker.ifttt.com";
const char* ntpServer = "pool.ntp.org";
const long  gmtOffset_sec = 28800;
const int   daylightOffset_sec = 0;
#define PIN_SDA 21
#define PIN_SCL 22
byte address = 0x27;
HIH6130 hih6130(address);
float ADC = 34;
float ADCvalue;
float VoltageValue;
const int CurrentSensor = 12;
float CurrentValue;
int smokesensor = 27;
int MQ2Sensor;
int buzzer = 33;
int led = 32;
float SOC;
int SOH;
int count;
unsigned long startMillis;
unsigned long currentMillis;
const int period = 1000;
float totalCoulumbs = 0.0;
float cap, health, cou, temp, hum, heat, volt, amp, smoke;
WebServer server(80);
  WiFi.begin(ssid, password);
    Serial.println("Connecting to WiFi..");
  Serial.println("Connected to the WiFi network");
  configTime(gmtOffset_sec, daylightOffset_sec, ntpServer);
  startMillis = millis();
  Wire.begin();
  EEPROM.begin(EEPROM_SIZE);
  count = EEPROM.read(0);
  pinMode(smokesensor, INPUT);
  pinMode(led, OUTPUT);
  pinMode(buzzer, OUTPUT);
  //Volatge measurement
  ADCvalue = analogRead(ADC);
  VoltageValue = ADCvalue / 4096 * 14.6 * (29203.54 / 30000);
  //Current measurement
  unsigned int x = 0;
  float AcsValue = 0.0, Samples = 0.0, AvgAcs = 0.0, CurrentValue = 0.0;
  for (int x = 0; x < 150; x++) {
    AcsValue = analogRead(CurrentSensor);
    Samples = Samples + AcsValue;
    delay (3);
  AvgAcs = Samples / 150.0;
  CurrentValue = (2.5 - (AvgAcs * (5.0 / 1024.0)) ) / 0.185;
  //Smoke measurement
  MQ2Sensor = analogRead(smokesensor);
  //Temperature, Humidity and Heat index measurement
  hih6130.readSensor();
  //Buzzer and LED
  if (hih6130.temperature_C > 60 || hih6130.temperature_C < -20 || MQ2Sensor > 400 || hih6130.humidity > 75) {
    digitalWrite(buzzer, HIGH);
    digitalWrite(led, HIGH);
  else {
    digitalWrite(buzzer, LOW);
    digitalWrite(led, LOW);
  //SOC measurement
  currentMillis = millis();
  if (currentMillis - startMillis >= period) {
    totalCoulumbs = totalCoulumbs + CurrentValue;
    float TotalAh = totalCoulumbs / 3600.0;
    SOC = ((50 - TotalAh) / 50) * 100;
    startMillis = currentMillis;
  //SOH and count measurement
  if ( SOC > 99.9) {
    count = count + 1;
    EEPROM.write(0, count);
  float percentage = count;
  SOH = ((2000 - percentage) / 2000) * 100;
  //Time measurement
struct tm timeinfo;
  if (!getLocalTime(&timeinfo)) {
    Serial.println("Failed to obtain time");
    return;
  //Serial.println(&timeinfo);
  //Google sheets
  makeIFTTTRequest1();
  makeIFTTTRequest2();
  makeIFTTTRequest3();
//Webserver
  server.handleClient();
void handle_OnConnect() {
  cap = SOC;
  health = SOH;
  cou = count;
  temp = hih6130.temperature_C;
  hum = hih6130.humidity;
  heat = hih6130.computeHeatIndex_C();
  volt = VoltageValue;
  amp = CurrentValue;
  smoke = MQ2Sensor;
  server.send(200, "text/html", SendHTML(cap, health, cou, temp, hum, heat, volt, amp, smoke));
void handle_NotFound() {
  server.send(404, "text/plain", "Not found");
  ptr += "<html>";
  ptr += "<head>";
  ptr += "<style>";
  ptr += "</style>";
  ptr += "};\n";
  ptr += "}\n";
  ptr += "</head>";
  ptr += "<body>";
  ptr += "</div>";
  ptr += (int)cap;
  ptr += "</div>";
  ptr += "</div>";
  ptr += (int)health;
  ptr += "</div>";
  ptr += "</div>";
  ptr += (int)cap;
  ptr += "</div>";
  ptr += "</div>";
  ptr += (int)temp;
  ptr += "</div>";
  ptr += "</div>";
  ptr += (int)hum;
  ptr += "</div>";
  ptr += "</div>";
  ptr += (int)heat;
  ptr += "</div>";
  ptr += "</div>";
  ptr += (int)volt;
  ptr += "</div>";
  ptr += "</div>";
  ptr += (int)amp;
  ptr += "</div>";
  ptr += "</div>";
  ptr += (int)smoke;
  ptr += "</div>";
  ptr += "</div>";
  ptr += "</body>";
  ptr += "</html>";
  return ptr;
void makeIFTTTRequest1() {
  Serial.print("Connecting to ");
  Serial.print(server1);
  WiFiClient client;
  int retries = 5;
  while (!!!client.connect(server1, 80) && (retries-- > 0)) {
    Serial.print(".");
  if (!!!client.connected()) {
    Serial.println("Failed to connect...");
  Serial.print("Request resource: ");
  Serial.println(resource1);
  String jsonObject1 = String("{\"value1\":\"") + hih6130.humidity + "\",\"value2\":\"" + hih6130.temperature_C
                       + "\",\"value3\":\"" + hih6130.computeHeatIndex_C() + "\"}";
  client.println(String("POST ") + resource1 + " HTTP/1.1");
  client.println(String("Host: ") + server1);
  client.println("Connection: close\r\nContent-Type: application/json");
  client.print("Content-Length: ");
  client.println(jsonObject1.length());
  client.println();
  client.println(jsonObject1);
  int timeout = 5 * 10; // 5 seconds
  while (!!!client.available() && (timeout-- > 0)) {
    delay(100);
  if (!!!client.available()) {
    Serial.println("No response...");
  while (client.available()) {
    Serial.write(client.read());
  Serial.println("\nclosing connection");
  client.stop();
void makeIFTTTRequest2() {
  Serial.print(server2);
  WiFiClient client;
  int retries = 5;
  while (!!!client.connect(server2, 80) && (retries-- > 0)) {
    Serial.print(".");
  Serial.println(resource2);
  String jsonObject2 = String("{\"value1\":\"") + MQ2Sensor + "\",\"value2\":\"" + CurrentValue
                       + "\",\"value3\":\"" + VoltageValue + "\"}";
  client.println(String("POST ") + resource2 + " HTTP/1.1");
  client.println(String("Host: ") + server2);
  client.println(jsonObject2.length());
  client.println();
  client.println(jsonObject2);
    delay(100);
  client.stop();
void makeIFTTTRequest3() {
  Serial.print(server3);
  WiFiClient client;
  int retries = 5;
  while (!!!client.connect(server3, 80) && (retries-- > 0)) {
    Serial.print(".");
  Serial.println(resource3);
  String jsonObject3 = String("{\"value1\":\"") + SOC + "\",\"value2\":\"" + SOH + "\",\"value3\":\"" + count + "\"}";
  client.println(String("POST ") + resource3 + " HTTP/1.1");
  client.println(String("Host: ") + server3);
  client.println(jsonObject3.length());
  client.println();
  client.println(jsonObject3);
    delay(100);
  client.stop();
first thing would be to get the time.
assuming you can log onto the internet, you can get the time.
there are quite a few examples of getting the time.
There should be examples that show how to create a string with the time, date, etc that you can play with to get information in the way you want to present it.
lastly, create the output for the font, color, etc you want and post the string.
the current way I get time is this
#include <time.h>
   printLocalTime();
   delay(30000);
void printLocalTime()
  struct tm timeinfo;
     return;
  Serial.println(&timeinfo, "%A, %B %d %Y %H:%M:%S");
So what you're saying is I need to make a string for this part of the code and add it ?
Yes
but what type of code is this like int, float or char
as i tried to make it as a string and it says invaalid tm
you are very short on information.
You are working on an informatic project and what is most needed in informatic projects is information
Why don't you post your modified code?
Are you expecting to get a full working code?
You can access the variables inside the tm.structure like shown in this sketch
#include <WiFi.h>
unsigned long MyTestTimer = 0;                   // variables MUST be of type unsigned long
const byte    OnBoard_LED = 2;
//const char *ssid     = "WLANBuero_EXT";
const   char *ssid     = "FRITZ!Box 7490";
const char *password = "";
const char* ntpServer = "fritz.box";
const long  gmtOffset_sec = 0;
const int   daylightOffset_sec = 7200;
#include <time.h>                   // time() ctime()
time_t now;                         // this is the epoch
tm myTimeInfo;                      // the structure tm holds time information in a more convient way
void showTime() {
  time(&now);                       // read the current time
  localtime_r(&now, &myTimeInfo);           // update the structure tm with the current time
  Serial.print("year:");
  Serial.print(myTimeInfo.tm_year + 1900);  // years since 1900
  Serial.print("\tmonth:");
  Serial.print(myTimeInfo.tm_mon + 1);      // January = 0 (!)
  Serial.print("\tday:");
  Serial.print(myTimeInfo.tm_mday);         // day of month
  Serial.print("\thour:");
  Serial.print(myTimeInfo.tm_hour);         // hours since midnight  0-23
  Serial.print("\tmin:");
  Serial.print(myTimeInfo.tm_min);          // minutes after the hour  0-59
  Serial.print("\tsec:");
  Serial.print(myTimeInfo.tm_sec);          // seconds after the minute  0-61*
  Serial.print("\twday");
  Serial.print(myTimeInfo.tm_wday);         // days since Sunday 0-6
  if (myTimeInfo.tm_isdst == 1)             // Daylight Saving Time flag
    Serial.print("\tDST");
    Serial.print("\tstandard");
void connectToWifi() {
  Serial.println(ssid);
  WiFi.persistent(false);
  WiFi.mode(WIFI_STA);
    BlinkHeartBeatLED(OnBoard_LED, 333);
    delay(332);
    Serial.print(".");
  Serial.print("\n connected.");
  Serial.println(WiFi.localIP() );
void synchroniseWith_NTP_Time() {
  Serial.print("configTime uses ntpServer ");
  Serial.println(ntpServer);
  Serial.print("synchronising time");
  while (myTimeInfo.tm_year + 1900 < 2000 ) {
    BlinkHeartBeatLED(OnBoard_LED, 100);
    delay(100);
    Serial.print(".");
  Serial.print("\n time synchronsized \n");
  showTime();
void PrintFileNameDateTime() {
  Serial.println( F("Code running comes from file ") );
  Serial.println(__FILE__);
  Serial.print( F("  compiled ") );
  Serial.print(__DATE__);
  Serial.print( F(" ") );
  Serial.println(__TIME__);
boolean TimePeriodIsOver (unsigned long &periodStartTime, unsigned long TimePeriod) {
  unsigned long currentMillis  = millis();
  if ( currentMillis - periodStartTime >= TimePeriod )
    periodStartTime = currentMillis; // set new expireTime
    return true;                // more time than TimePeriod) has elapsed since last time if-condition was true
  else return false;            // not expired
void BlinkHeartBeatLED(int IO_Pin, int BlinkPeriod) {
  static unsigned long MyBlinkTimer;
  pinMode(IO_Pin, OUTPUT);
  if ( TimePeriodIsOver(MyBlinkTimer,BlinkPeriod) ) {
    digitalWrite(IO_Pin,!digitalRead(IO_Pin) );
  Serial.println("\n Setup-Start \n");
  PrintFileNameDateTime();
  connectToWifi();
  synchroniseWith_NTP_Time();
  BlinkHeartBeatLED(OnBoard_LED,100);
  if ( TimePeriodIsOver(MyTestTimer,1000) ) {
    showTime();
best regards Stefan
Thank you for the code, now I can convert the time into int and introduce it into HTML code as each year, month, the hour is separated.
Thank you
