How to add dc bias to ac signal?
I want to measure ac signal (ranging from +2.5 to -2.5 V) using arduino. How do i add a dc 2.5V to the ac signal so that it ranges from 0 to 5V ?
Describe the signal source. Depending on the source characteristics, a voltage divider similar to this will work:
But that circuit is assuming a balanced signal, which might not be the case (for instance a
signal composed of short 2.5V pulses with the normal level -2.5V would fail with the above
circuit).
A sinusoidal signal would be fine, but you need to add a 1k or so in series with the analog
pin to limit current on initial transients.
An opamp in differential-amplifier configuration is a good solution for level-shifting and
scaling analog signals accurately.
