How to add hysteresis to threshold values?
This code compares the analog input value against two thresholds, having three voltage regions. Then it will turn on an LED according to what region the read voltage is in.
The problem is that when the voltage read is very close to the threshold, the noise will disturb the output, resulting in an uncontrolled switching between LEDs.
I would need to add some sort of HYSTERESIS around my thresholds to avoid the uncontrolled switching, but I have no idea how to write this into the code language. Would anyone be able to help me writing the threshold bit?
This is the full code:
// these constant won't change:
const int BatteryVoltagePin = 14;   // the pin that battery voltage is attached to
const int GreenLedPin = 3;           // the pin that the green LED (On charge) is attached to
const int OrangeLedPin = 4;          // the pin that the orange LED (no risk) is attached to
const int RedLedPin = 5;             // the pin that the red LED (low battery) is attached to
// Variables will change:
int currentVoltage ;         // current voltage value
int previousVoltage ;     // previous voltage value
  // initialize the battery voltage pin as a input:
  pinMode(BatteryVoltagePin, INPUT);
  // initialize the green LED as an output:
  pinMode(GreenLedPin, OUTPUT);
  // initialize the orange LED as an output:
  pinMode(OrangeLedPin, OUTPUT);
  // initialize the red LED as an output:
  pinMode(RedLedPin, OUTPUT);
  // read the voltage across the battery voltage pin:
  currentVoltage = digitalRead(BatteryVoltagePin);
  // compare the current voltage value to its previous value
 if (currentVoltage != previousVoltage)
 delay(10);
    // value above maximum threshold
     if ((( ( analogRead(BatteryVoltagePin) ) > ( 699 ) ))
        digitalWrite(GreenLedPin, HIGH);
          digitalWrite(GreenLedPin, LOW );
    //value between two thresholds (middle region)
     if (( ( ( analogRead(BatteryVoltagePin) ) <= ( 699 ) ) && ( ( analogRead(BatteryVoltagePin) ) >= ( 628 ) ) ))
        digitalWrite(OrangeLedPin, HIGH );
          digitalWrite(OrangeLedPin, LOW );
    // value below minimum threshold
     if (( ( analogRead(BatteryVoltagePin) ) < ( 628 ) ))
        digitalWrite(RedLedPin, HIGH);
          digitalWrite(RedLedPin, LOW );
  // save the current state as the last state,
  //for next time through the loop
  previousVoltage = currentVoltage;
All sorts of problems. You got way too far ahead without testing.
Worst of all, you can't read an analog voltage using a digital read.
