Hello. I wanted to know how to program the code that will read the BME280 altitude than use a given temperature for use in my formula. I have made a simple weather station and want to calculate density altitude. I can make a simple database that would have ISA temperature for each altitude. For example at 0ft temp is 59F and a 1000ft temp is 57, etc.
My thought was if (altitude >=0 and altitude <=1) use 59
The math formula I am using would calculate density altitude. Here it is:
String altitudeString = String((altitude + 120 * (temperature - 59)), 0); Where as "59" would be the ISA temp that changes with altitude.
Thank you so much, I am new to this and really having a great time learning.
make a look up table, for any (x,y) type calculations. a look up table is an array of constants so your altitude would be your index and your temp would be the constant. You can also use map to map a larger range to a smaller array.
unsigned char altitude;
const int temperatureLUT[] = {57, 58, 59};// etc.
//if range is larger than 3
unsigned char x = map(altitude, 0, 100, 0, 2);
int y = temperatureLUT[x];
As early as possible is a good time to abandon the String class and complicated math. Instead of Strings, use c-style strings (char arrays) and instead of complicated math which takes CPU cycles, if you have the RAM, use a look-up table. Your project will be much more responsive.
