How to add items in Arduino IDE menu?
Hi everyone.
I found the board.txt but looks not like the right one, what's wrong with that?
Thanks
Adam
C:\Program Files (x86)\Arduino\hardware\arduino\avr\firmwares\wifishield\wifi_dnld\src\SOFTWARE_FRAMEWORK\BOARDS
/* This header file is part of the ATMEL AVR-UC3-SoftwareFramework-1.7.0 Release */
/*This file is prepared for Doxygen automatic documentation generation.*/
/*! \file *********************************************************************
 * \brief Standard board header file.
 * This file includes the appropriate board header file according to the
 * defined board.
 * - Compiler:           IAR EWAVR32 and GNU GCC for AVR32
 * - Supported devices:  All AVR32 devices can be used.
 * - AppNote:
 * \author               Atmel Corporation: http://www.atmel.com \n
 *                       Support and FAQ: http://support.atmel.no/
/* Copyright (c) 2009 Atmel Corporation. All rights reserved.
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions are met:
 * 1. Redistributions of source code must retain the above copyright notice, this
 * list of conditions and the following disclaimer.
 * 2. Redistributions in binary form must reproduce the above copyright notice,
 * this list of conditions and the following disclaimer in the documentation
 * and/or other materials provided with the distribution.
 * 3. The name of Atmel may not be used to endorse or promote products derived
 * from this software without specific prior written permission.
 * 4. This software may only be redistributed and used in connection with an Atmel
 * AVR product.
 * THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR IMPLIED
 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
 * MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE
 * EXPRESSLY AND SPECIFICALLY DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR
 * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
 * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
 * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
 * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE
#ifndef _BOARD_H_
#define _BOARD_H_
#include <avr32/io.h>
/*! \name Base Boards
#define EVK1100           1   //!< AT32UC3A EVK1100 board.
#define EVK1101           2   //!< AT32UC3B EVK1101 board.
#define UC3C_EK           3   //!< AT32UC3C UC3C_EK board.
#define EVK1104           4   //!< AT32UC3A3 EVK1104 board.
#define EVK1105           5   //!< AT32UC3A EVK1105 board.
#define STK1000           6   //!< AT32AP7000 STK1000 board.
#define NGW100            7   //!< AT32AP7000 NGW100 board.
#define STK600_RCUC3L0    8   //!< STK600 RCUC3L0 board.
#define UC3L_EK           9   //!< AT32UC3L-EK board.
#define USER_BOARD        99  //!< User-reserved board (if any).
/*! \name Extension Boards
#define EXT1102           1   //!< AT32UC3B EXT1102 board.
#define MC300             2   //!< AT32UC3 MC300 board.
#define USER_EXT_BOARD    99  //!< User-reserved extension board (if any).
#if BOARD == EVK1100
  #include "EVK1100/evk1100.h"
#elif BOARD == EVK1101
  #include "EVK1101/evk1101.h"
#elif BOARD == UC3C_EK
  #include "UC3C_EK/uc3c_ek.h"
#elif BOARD == EVK1104
  #include "EVK1104/evk1104.h"
#elif BOARD == EVK1105
  #include "EVK1105/evk1105.h"
#elif BOARD == STK1000
  #include "STK1000/stk1000.h"
#elif BOARD == NGW100
  #include "NGW100/ngw100.h"
#elif BOARD == STK600_RCUC3L0
  #include "STK600/RCUC3L0/stk600_rcuc3l0.h"
#elif BOARD == UC3L_EK
  #include "UC3L_EK/uc3l_ek.h"
#elif BOARD == ARDUINO
  #include "ARDUINO/arduino.h"
#else
  #error No known AVR32 board defined
#endif
#if (defined EXT_BOARD)
  #if EXT_BOARD == EXT1102
    #include "EXT1102/ext1102.h"
  #elif EXT_BOARD == MC300
    #include "MC300/mc300.h"
  #elif EXT_BOARD == USER_EXT_BOARD
    // User-reserved area: #include the header file of your extension board here
    // (if any).
  #endif
#endif
#ifndef FRCOSC
  #define FRCOSC    AVR32_PM_RCOSC_FREQUENCY  //!< Default RCOsc frequency.
#endif
#endif  // _BOARD_H_
which board are you looking for?
Thanks
ESP32,
don't you really want the processor, not the board?
ESP32-WROOM-32 the board, I'd like to have: erase all SPIFFS files before upload.
This path obviously has nothing to do with ESP32 hardware because contains "hardware/arduino/avr" part. You need to find the "hardware/esp32" directory.
For example, the ESP32 boards.txt file on my PC is situated in
T:\Arduino\portable\packages\esp32\hardware\esp32\1.0.4\boards.txt
