How to add L & R Brake to my project
Hi folks , I want to add Left & Right Brake to the code I am using for a Flight sim controller i am building using the Arduino Micro . The code has Aux1 & Aux2 already , but they are used by the Slats and Flaps. I am a real newbie to programming and I have tried but keep getting errors. I want to add the L & R brake to Pin A10 & A6 or would I use different pins.
Here is the code I am using , ( Not My Code).
// Requires Arduino Joystick Library GitHub - MHeironimus/ArduinoJoystickLibrary: An Arduino library that adds one or more joysticks to the list of HID devices an Arduino Leonardo or Arduino Micro can support.
#include <Joystick.h>
Joystick_ Joystick ;
int JoystickX;
int JoystickY;
int JoystickZ;
int Throttle;
int Rudder;
int Aux1;
int Aux2;
int currentButtonState0;
int lastButtonState0;
int currentButtonState1;
int lastButtonState1;
int currentButtonState2;
int lastButtonState2;
int currentButtonState3;
int lastButtonState3;
int currentButtonState4;
int lastButtonState4;
int currentButtonState5;
int lastButtonState5;
int currentButtonState6;
int lastButtonState6;
pinMode(2, INPUT_PULLUP);
pinMode(3, INPUT_PULLUP);
pinMode(4, INPUT_PULLUP);
pinMode(5, INPUT_PULLUP);
pinMode(6, INPUT_PULLUP);
pinMode(7, INPUT_PULLUP);
// Initialize Joystick Library
Joystick.begin();
Joystick.setXAxisRange(0, 965);
Joystick.setYAxisRange(192, 522);
Joystick.setZAxisRange(143, 735);
Joystick.setRxAxisRange(158, 456);
Joystick.setRyAxisRange(158, 456);
Joystick.setThrottleRange(154, 448);
// Read Joystick
JoystickX = analogRead(A0);
JoystickY = analogRead(A1);
JoystickZ=analogRead(A8);
Throttle=analogRead(A2);
Aux1=analogRead(A9);
Aux2=analogRead(A3);
Serial.print(JoystickX);
Serial.print(" ");
Serial.print(JoystickY);
Serial.print(" ");
Serial.println(JoystickZ);
// Read Switches
int currentButtonState0 = !digitalRead(2); // Button 0
if (currentButtonState0 != lastButtonState0)
Joystick.setButton(0, currentButtonState0);
lastButtonState0 = currentButtonState0;
int currentButtonState1 = !digitalRead(3); // Button 1
if (currentButtonState1 != lastButtonState1)
Joystick.setButton(1, currentButtonState1);
lastButtonState1 = currentButtonState1;
int currentButtonState2 = !digitalRead(4); // Button 2
if (currentButtonState2 != lastButtonState2)
Joystick.setButton(2, currentButtonState2);
lastButtonState2 = currentButtonState2;
int currentButtonState3 = !digitalRead(5); // Button 3
if (currentButtonState3 != lastButtonState3)
Joystick.setButton(3, currentButtonState3);
lastButtonState3 = currentButtonState3;
int currentButtonState4 = !digitalRead(6); // Button 4
if (currentButtonState4 != lastButtonState4)
Joystick.setButton(4, currentButtonState4);
lastButtonState4 = currentButtonState4;
int currentButtonState5 = !digitalRead(7); // Button 5
if (currentButtonState5 != lastButtonState5)
Joystick.setButton(5, currentButtonState5);
lastButtonState5 = currentButtonState5;
// Output Controls
Joystick.setXAxis(JoystickX);
Joystick.setYAxis(JoystickY);
Joystick.setZAxis(JoystickZ);
Joystick.setThrottle(Throttle);
Joystick.setRxAxis(Aux1);
Joystick.setRyAxis(Aux2);
Joystick.sendState();
You have a global variable with the same name.
That often causes problems, but not here yet, I think.
In fact, the only variables that need global scope are the "lastButtonState" ones - all the others could be defined inside the loop function.
Your code is hard to read, and it would help you and us if you gave the pins descriptive names, and put your code inside code tags so that we can be assured the forum software hasn't mangled it and make it easier to copy.
What have you tried, and what were the errors?
Please copy and paste the entire error listing here verbatim, not just a few lines.
Ok first let me clarify this is not my code. As is, the code compiles fine. I tried adding Left brake and right brake to the code but i really do not what i am doing. I want to use Pins A10 and A6 for L & R Brake , but I do not know how to code it , if you could direct me on how to do it that would be awesome. The code has an Aux1 & Aux2 but they are used by the Slats and Flaps . Any help would be great ! Thanks
I'm sorry, I can't direct someone who can't code, on how to code. It's a long learning process. I urge you to begin now.
In the sketch you posted, or in a different one you didn't post?
in one I did didn't post , the one i posted is the original as is. I tired coping the commands that were listed in the code and adding different variable names.
aarg Thanks for your reply. Here is the Code I tried to modify and the errors. Ok thanks for teaching me ,now I know about Code Tags
// Requires Arduino Joystick Library https://github.com/MHeironimus/ArduinoJoystickLibrary
int JoystickX;
int JoystickY;
int JoystickZ;
int Throttle;
int Rudder;
int Aux1;
int Aux2;
int LeftBrake;                         //  I added this
int RightBrake;                      //  I added this
 Joystick.begin();
 Joystick.setLeftBrakeBrakeRange(0, 448);                     //  I added this
 Joystick.setRightBrakeRange(0, 448);                             //  I added this
 // Read Joystick
 JoystickZ = analogRead(A8);
 Throttle = analogRead(A2);
 Aux1 = analogRead(A9);
 Aux2 = analogRead(A3);
 LeftBrake = analogRead(A10);                                   //  I added this
 RightBrake = analogRead(A6);                                  //  I added this
 Serial.print("   ");
 Serial.print("   ");
 // Read Switches
 // Output Controls
 Joystick.setLeftBrake(LeftBrake);                              //  I added this
 Joystick.setRightBrake(Rightbrake);                         //  I added this
Here are the errors
[code]
int JoystickX;
int JoystickY;
int JoystickZ;
int Throttle;
int Rudder;
int Aux1;
int Aux2;
Joystick.begin();
// Read Joystick
Serial.print(" ");
Serial.print(" ");
// Read Switches
// Output Controls
here are the errors
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "Arduino Micro"
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\alima\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\alima\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\alima\Documents\Arduino\libraries -fqbn=arduino:avr:micro -ide-version=10819 -build-path C:\Users\alima\AppData\Local\Temp\arduino_build_826385 -warnings=none -build-cache C:\Users\alima\AppData\Local\Temp\arduino_cache_419920 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\alima\Documents\ArduinoData\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\alima\Documents\ArduinoData\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Users\alima\Documents\ArduinoData\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\alima\Documents\ArduinoData\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Users\alima\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\alima\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17 -verbose C:\Users\alima\Downloads\Flight_Yoke_Code-COMPILED SUCCESSFULLY\Flight_Yoke_Code\Flight_Yoke_Code.ino
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\arduino-builder -compile -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\alima\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\alima\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\alima\Documents\Arduino\libraries -fqbn=arduino:avr:micro -ide-version=10819 -build-path C:\Users\alima\AppData\Local\Temp\arduino_build_826385 -warnings=none -build-cache C:\Users\alima\AppData\Local\Temp\arduino_cache_419920 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\alima\Documents\ArduinoData\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\alima\Documents\ArduinoData\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Users\alima\Documents\ArduinoData\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\alima\Documents\ArduinoData\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Users\alima\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\alima\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17 -verbose C:\Users\alima\Downloads\Flight_Yoke_Code-COMPILED SUCCESSFULLY\Flight_Yoke_Code\Flight_Yoke_Code.ino
Using board 'micro' from platform in folder: C:\Users\alima\Documents\ArduinoData\packages\arduino\hardware\avr\1.8.5
Using core 'arduino' from platform in folder: C:\Users\alima\Documents\ArduinoData\packages\arduino\hardware\avr\1.8.5
Detecting libraries used...
"C:\Users\alima\Documents\ArduinoData\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER="Unknown"" "-DUSB_PRODUCT="Arduino Micro"" "-IC:\Users\alima\Documents\ArduinoData\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\alima\Documents\ArduinoData\packages\arduino\hardware\avr\1.8.5\variants\micro" "C:\Users\alima\AppData\Local\Temp\arduino_build_826385\sketch\Flight_Yoke_Code.ino.cpp" -o nul
Alternatives for Joystick.h: [ArduinoJoystickLibrary-master@2.1.1]
ResolveLibrary(Joystick.h)
-> candidates: [ArduinoJoystickLibrary-master@2.1.1]
"C:\Users\alima\Documents\ArduinoData\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER="Unknown"" "-DUSB_PRODUCT="Arduino Micro"" "-IC:\Users\alima\Documents\ArduinoData\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\alima\Documents\ArduinoData\packages\arduino\hardware\avr\1.8.5\variants\micro" "-IC:\Users\alima\Documents\Arduino\libraries\ArduinoJoystickLibrary-master\src" "C:\Users\alima\AppData\Local\Temp\arduino_build_826385\sketch\Flight_Yoke_Code.ino.cpp" -o nul
"C:\Users\alima\Documents\ArduinoData\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER="Unknown"" "-DUSB_PRODUCT="Arduino Micro"" "-IC:\Users\alima\Documents\ArduinoData\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\alima\Documents\ArduinoData\packages\arduino\hardware\avr\1.8.5\variants\micro" "-IC:\Users\alima\Documents\Arduino\libraries\ArduinoJoystickLibrary-master\src" "C:\Users\alima\Documents\Arduino\libraries\ArduinoJoystickLibrary-master\src\DynamicHID\DynamicHID.cpp" -o nul
"C:\Users\alima\Documents\ArduinoData\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER="Unknown"" "-DUSB_PRODUCT="Arduino Micro"" "-IC:\Users\alima\Documents\ArduinoData\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\alima\Documents\ArduinoData\packages\arduino\hardware\avr\1.8.5\variants\micro" "-IC:\Users\alima\Documents\Arduino\libraries\ArduinoJoystickLibrary-master\src" "C:\Users\alima\Documents\Arduino\libraries\ArduinoJoystickLibrary-master\src\Joystick.cpp" -o nul
Generating function prototypes...
"C:\Users\alima\Documents\ArduinoData\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER="Unknown"" "-DUSB_PRODUCT="Arduino Micro"" "-IC:\Users\alima\Documents\ArduinoData\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\alima\Documents\ArduinoData\packages\arduino\hardware\avr\1.8.5\variants\micro" "-IC:\Users\alima\Documents\Arduino\libraries\ArduinoJoystickLibrary-master\src" "C:\Users\alima\AppData\Local\Temp\arduino_build_826385\sketch\Flight_Yoke_Code.ino.cpp" -o "C:\Users\alima\AppData\Local\Temp\arduino_build_826385\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\alima\AppData\Local\Temp\arduino_build_826385\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\alima\Documents\ArduinoData\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER="Unknown"" "-DUSB_PRODUCT="Arduino Micro"" "-IC:\Users\alima\Documents\ArduinoData\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\alima\Documents\ArduinoData\packages\arduino\hardware\avr\1.8.5\variants\micro" "-IC:\Users\alima\Documents\Arduino\libraries\ArduinoJoystickLibrary-master\src" "C:\Users\alima\AppData\Local\Temp\arduino_build_826385\sketch\Flight_Yoke_Code.ino.cpp" -o "C:\Users\alima\AppData\Local\Temp\arduino_build_826385\sketch\Flight_Yoke_Code.ino.cpp.o"
C:\Users\alima\Downloads\Flight_Yoke_Code-COMPILED SUCCESSFULLY\Flight_Yoke_Code\Flight_Yoke_Code.ino: In function 'void setup()':
Flight_Yoke_Code:45:12: error: 'class Joystick_' has no member named 'setLeftBrakeBrakeRange'; did you mean 'setBrakeRange'?
        setBrakeRange
Flight_Yoke_Code:46:12: error: 'class Joystick_' has no member named 'setRightBrakeRange'; did you mean 'setBrakeRange'?
        setBrakeRange
C:\Users\alima\Downloads\Flight_Yoke_Code-COMPILED SUCCESSFULLY\Flight_Yoke_Code\Flight_Yoke_Code.ino: In function 'void loop()':
Flight_Yoke_Code:118:12: error: 'class Joystick_' has no member named 'setLeftBrake'; did you mean 'setBrake'?
        setBrake
Flight_Yoke_Code:119:12: error: 'class Joystick_' has no member named 'setRightBrake'; did you mean 'setBrake'?
        setBrake
Flight_Yoke_Code:119:26: error: 'Rightbrake' was not declared in this scope
C:\Users\alima\Downloads\Flight_Yoke_Code-COMPILED SUCCESSFULLY\Flight_Yoke_Code\Flight_Yoke_Code.ino:119:26: note: suggested alternative: 'RightBrake'
                      RightBrake
Using library ArduinoJoystickLibrary-master at version 2.1.1 in folder: C:\Users\alima\Documents\Arduino\libraries\ArduinoJoystickLibrary-master
exit status 1
Please edit your post and put both the code, and the error listing, inside code tags. Consult the forum introduction threads if you don't know how to do that.
Done , is that ok ?
Code is done, errors no. Also I see some code outside tags. I can't quickly identify where you went wrong, can you please check it out and fix it?
What you do in the editor, is highlight the section you want in tags, and select the </> button.
sorry here you go, and again thanks for your help and patients.
"C:\\Users\\alima\\Documents\\ArduinoData\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\alima\\Documents\\ArduinoData\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\alima\\Documents\\ArduinoData\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\micro" "C:\\Users\\alima\\AppData\\Local\\Temp\\arduino_build_826385\\sketch\\Flight_Yoke_Code.ino.cpp" -o nul
"C:\\Users\\alima\\Documents\\ArduinoData\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\alima\\Documents\\ArduinoData\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\alima\\Documents\\ArduinoData\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\micro" "-IC:\\Users\\alima\\Documents\\Arduino\\libraries\\ArduinoJoystickLibrary-master\\src" "C:\\Users\\alima\\AppData\\Local\\Temp\\arduino_build_826385\\sketch\\Flight_Yoke_Code.ino.cpp" -o nul
"C:\\Users\\alima\\Documents\\ArduinoData\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\alima\\Documents\\ArduinoData\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\alima\\Documents\\ArduinoData\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\micro" "-IC:\\Users\\alima\\Documents\\Arduino\\libraries\\ArduinoJoystickLibrary-master\\src" "C:\\Users\\alima\\Documents\\Arduino\\libraries\\ArduinoJoystickLibrary-master\\src\\DynamicHID\\DynamicHID.cpp" -o nul
"C:\\Users\\alima\\Documents\\ArduinoData\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\alima\\Documents\\ArduinoData\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\alima\\Documents\\ArduinoData\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\micro" "-IC:\\Users\\alima\\Documents\\Arduino\\libraries\\ArduinoJoystickLibrary-master\\src" "C:\\Users\\alima\\Documents\\Arduino\\libraries\\ArduinoJoystickLibrary-master\\src\\Joystick.cpp" -o nul
"C:\\Users\\alima\\Documents\\ArduinoData\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\alima\\Documents\\ArduinoData\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\alima\\Documents\\ArduinoData\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\micro" "-IC:\\Users\\alima\\Documents\\Arduino\\libraries\\ArduinoJoystickLibrary-master\\src" "C:\\Users\\alima\\AppData\\Local\\Temp\\arduino_build_826385\\sketch\\Flight_Yoke_Code.ino.cpp" -o "C:\\Users\\alima\\AppData\\Local\\Temp\\arduino_build_826385\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\alima\\AppData\\Local\\Temp\\arduino_build_826385\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\alima\\Documents\\ArduinoData\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\alima\\Documents\\ArduinoData\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\alima\\Documents\\ArduinoData\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\micro" "-IC:\\Users\\alima\\Documents\\Arduino\\libraries\\ArduinoJoystickLibrary-master\\src" "C:\\Users\\alima\\AppData\\Local\\Temp\\arduino_build_826385\\sketch\\Flight_Yoke_Code.ino.cpp" -o "C:\\Users\\alima\\AppData\\Local\\Temp\\arduino_build_826385\\sketch\\Flight_Yoke_Code.ino.cpp.o"
            setBrakeRange
            setBrakeRange
            setBrake
            setBrake
                          RightBrake
exit status 1
That does take care of the error listing. But there seem to be two sketches. Can you just repost the one you modified, in a new post, to start with a clean slate? The error listing should match the code.
No problem
int JoystickX;
int JoystickY;
int JoystickZ;
int Throttle;
int Rudder;
int Aux1;
int Aux2;
  Joystick.begin();
  // Read Joystick
  Serial.print("   ");
  Serial.print("   ");
  // Read Switches
  // Output Controls
Here are the errors
Compiling sketch...
            setBrakeRange
            setBrakeRange
            setBrake
            setBrake
                          RightBrake
exit status 1
Where are these methods of the Joystick class defined?
You do realize, you can't just make up new functions, code has to exist for them somewhere?
The compiler is not a thinking mind, or a mind reader.
Sometimes the first error causes subsequent errors that disappear if you fix the first one. Did you mean
  Joystick.setLeftBrakeRange(0, 448);    //  I added this
? Note the possible typo
Ok lol. boy was i off. I understand that now , but I'm not getting the possible typo , what do you mean.
setLeftBrakeBrakeRange != setLeftBrakeRange
OMG wow good eye ! ok i fixed that
Ok here are the errors again
Compiling sketch...
Flight_Yoke_Code:45:12: error: 'class Joystick_' has no member named 'setLeftBrakeRange'; did you mean 'setBrakeRange'?
            setBrakeRange
            setBrakeRange
            setBrake
            setBrake
                          RightBrake
exit status 1
If you look in Joystick.h, you'll see that the Joystick_ class has no member functions named:
setLeftBrakeBrakeRange, setRightBrakeRange, setLeftBrake, or setRightBrake. The compiler errors are telling you exactly that. As already noted, you can't just make stuff up. You must work with the member function that the class has, modify it as you need, or write your own.
