calvingloster:
Your input pin will still see 5v as the potential difference between the pin and the input pin is 5v irrespective of what goes on in between the arduino and the input pin.
So you say that even if I put a led with resistor the pin on l293d driver will see incoming voltage as 5 volts? But when I test it with multimeter it shows me that voltages is ~3.2V
