Hi, I m Hermanto from indonesia.
here I have a problem adding ID to the modbusSlave program arduino. arduino uno as slave and using RS 485 converter. Please Help me.
#include <modbus.h>
#include <modbusDevice.h>
#include <modbusRegBank.h>
#include <modbusSlave.h>
modbusDevice regBank;
modbusSlave slave;
#define RS485TxEnablePin 2
#define RS485Baud 9600
#define RS485Format SERIAL_8E1
#define LED1 11
#define LED2 12
//Assign the modbus device ID.
regBank.setId(1);
modbus registers follow the following format
00001-09999 Digital Outputs, A master device can read and write to these registers
10001-19999 Digital Inputs, A master device can only read the values from these registers
30001-39999 Analog Inputs, A master device can only read the values from these registers
40001-49999 Analog Outputs, A master device can read and write to these registers
Analog values are 16 bit unsigned words stored with a range of 0-32767
Digital values are stored as bytes, a zero value is OFF and any nonzer value is ON
//Add Analog Input registers to the register bank
regBank.add(30001);
regBank.add(30003);
//Add Analog Output registers to the register bank
regBank.add(40001);
regBank.add(40002);
slave._device = ®Bank;
slave.setBaud(&Serial, RS485Baud, RS485Format, RS485TxEnablePin);
pinMode(LED1, OUTPUT);
pinMode(LED2, OUTPUT);
digitalWrite(LED1, regBank.get(40001));
digitalWrite(LED2, regBank.get(40002));
regBank.set(30001, (word) analogRead(A0)); //from 0 - 1023
regBank.set(30003, (word) analogRead(A1)); //from 0 - 1023
slave.run();
