Ok, so I have an autonomous car, and I want to track it's relative position to it's origin, in an area of about 1 m2.
Can I use a wifi module for this? How precise will this be?
Or perhaps what module will be suitable
NB: Precision is quite a priority
Probably bluetooth signal strength triangulation is the easiest way.
Pozyx maybe.
Or place a grid of sensors in the specific area the robot moves on.
Bluetooth signal strength may work, if you can find a way to sufficiently precise measure this from at least three different points around the area.
wvmarle:
Pozyx maybe.Or place a grid of sensors in the specific area the robot moves on.
Just checked out Pozyx, way over cost budget. The project is quite small.
Well, it's not a trivial thing you're asking for - and I can tell you that even without you having defined the required precision.
Yeah I figured. Ok, thanks @IndianaTux and @wvmarle. I'll try and figure out bluetooth triangulation. Any suggestions on where I should start from? devices I could use?
