Dear all,
I want to adjust the precale factor on Timer0. Using Arduino Playground - TimerPWMCheatsheet I find I can do this with:
In the beginning of wiring.c you can find:
// the prescaler is set so that timer0 ticks every 64 clock cycles, and the
// the overflow handler is called every 256 ticks.
#define MICROSECONDS_PER_TIMER0_OVERFLOW (clockCyclesToMicroseconds(64 * 256))You need to modify the prescale factor in this function to the corresponding line
For fast PWM (default):
#define MICROSECONDS_PER_TIMER0_OVERFLOW (clockCyclesToMicroseconds(PRESCALE_FACTOR* 256))
For phase-correct PWM :
#define MICROSECONDS_PER_TIMER0_OVERFLOW (clockCyclesToMicroseconds(PRESCALE_FACTOR * 510))
What I would like to do is replace PRESCALE_FACTOR with a global variable in the appropriate core file, so I can change this value in my sketch if I change the prescaler there. The variable needs to have a default value of 64. I tried to replace it with an unsigned long variable, but no matter where I put the variable (wiring.c, wiring_private.h, arduino.h) I get errors the variable has multiple defines.
I would like to change the prescaler to 1, because I need the extra PWM on pin 5. I realize the timer ISR will be called much more often (64 times I guess), I hope that doesn't intrude too much.
Any tips how to tackle this are welcome.
Cheers,
Jack
