In the process of trying to understand what data to send to Neopixels to control them and we are not understanding what bytes to send to turn on and off RGB colors.
// include the neo pixel library
// The number of LEDs being driven. This dictates how much data is expected in each frame read from the serial port.
static const int NUM_LEDS = 256;
// Parameter 1 = number of pixels in strip
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_RGB Pixels are wired for RGB bitstream
// NEO_GRB Pixels are wired for GRB bitstream
// NEO_KHZ400 400 KHz bitstream (e.g. FLORA pixels)
// NEO_KHZ800 800 KHz bitstream (e.g. High Density LED strip)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(
NUM_LEDS, // Number of pixels in strip
12, // Pin number (most are valid)
NEO_GRB + NEO_KHZ800 // pixel type flags, add together as needed:
// NEO_KHZ400 400 KHz bitstream (e.g. Old FLORA pixels)
// NEO_KHZ800 800 KHz bitstream (e.g. New FLORA pixels and most WS2811 strips)
// Buffer used to read LED data from Serial.
// TODO: Direct access to the Adafruit_NeoPixel buffer would cut memory usage in half
char colorValues[NUM_LEDS*3];
// Init the NeoPixel library and turn off all the LEDs
strip.begin();
strip.show();
// Do a quick test/demo to show that things are working
for (int i=0; i<60; i++) { flashAll(strip.Color((i%20)*2,i%30,i%60)); delay(10); }
// Initialize the buffer to all black
memset(colorValues, 0, sizeof(colorValues));
// Initialize serial and wait for port to open:
while (!Serial) {
; // wait for port to be ready
// Tell the computer that we're ready for data
Serial.println("READY");
while (true) {
int bufferPos = 0;
// Read the data for each pixel
while (bufferPos < NUM_LEDS*3) {
int color = Serial.read();
if (color >= 0) {
colorValues[bufferPos++] = color;
// Feed the data to the NeoPixel library
for(int i=0; i<NUM_LEDS; i++) {
int d = i*3;
uint32_t c = strip.Color(colorValues[d], colorValues[d+1], colorValues[d+2]);
strip.setPixelColor(i, c);
// update the strip
strip.show();
// Clear up the serial buffer
while (Serial.available() > 0) Serial.read();
// Let the sender know we're ready for more data
void flashAll(uint32_t color) {
for (int i=0; i < NUM_LEDS; i++) {
strip.setPixelColor(i, color);
strip.show();
I am assuming that we need to send 3 color values (0-255) for every LED so for 1 Neopixel, we need to send "255 0 0" to turn on the RED LED (assuming RGB is the color order) and "0 0 0" to turn it off.
However upon uploading the sketch and trying to enter these commands directly into the Serial Monitor, we get different results (which also dramatically change based on if "no line ending" or "newline" is selected in the bottom). No matter what we send, we cannot seem to turn off the LED with just 0's.
Can anyone shed some light on how to input bytes into the Serial Monitor to control just the R, G, B or turn off the LED entirely? Or is it not possible with Serial Monitor and we need to send serial from a different program?
Thank you.
