You could try a basic framework like this:
#include <SPI.h>
//pins
const uint8_t
pinRST = 9, //reset
pinSS = 10, //slave select
pinMOSI = 11, //master out
pinMISO = 12, //master in
pinCLK = 13; //serial clock
//quick and dirty class for basic GPIO writing
class myPortExpander
#define WR_CMD 0x40 //control byte, slave address 0, R/nW=0 (write)
#define RD_CMD 0x41 //control byte, slave address 0, R/nW=1 (read)
#define IODIR 0x00 //address of I/O direction register pair
#define GPIO 0x12 //address of port data register pair
private:
uint8_t _pinSS;
uint8_t _pinRST;
void write16( uint8_t addr, uint16_t data )
digitalWrite( _pinSS, LOW );
SPI.transfer( WR_CMD );
SPI.transfer( addr );
SPI.transfer( (uint16_t)( data & 0xff ) );
SPI.transfer( (uint16_t)( (data >> 8) & 0xff) );
digitalWrite( _pinSS, HIGH);
}//write16
uint16_t read16( uint8_t addr )
uint16_t retval = 0;
SPI.transfer( RD_CMD );
retval |= SPI.transfer(0);
retval |= (uint16_t)(SPI.transfer(0) << 8);
digitalWrite( _pinSS, HIGH );
return retval;
}//read16
public:
myPortExpander( uint8_t pinRST, uint8_t pinSS )
_pinRST = pinRST;
_pinSS = pinSS;
}//myPortExpander
void begin( void )
pinMode( _pinRST, OUTPUT );
digitalWrite( _pinRST, LOW );
pinMode( _pinSS, OUTPUT ); //out SS
digitalWrite( 11, OUTPUT ); //MOSI
digitalWrite( 12, INPUT_PULLUP ); //MISO
digitalWrite( 13, OUTPUT ); //CLK
delayMicroseconds( 100ul );
digitalWrite( _pinRST, HIGH );
}//begin
void setGPIODir( uint16_t dir )
write16( IODIR, dir );
}//setGPIODir
void setGPIO( uint16_t val )
write16( GPIO, val );
}//setGPIO
};//myPortExpander
//instance of class object myPortX(pander)
myPortExpander myPortX( pinRST, pinSS );
//patterns for the 7-seg display
uint8_t
grSegments[] =
//pgfedcba
0b00111111, //0
0b00000110, //1
0b01011011, //2
0b01001111, //3
0b01100110, //4
0b01101101, //5
0b01111101, //6
0b00000111, //7
0b01111111, //8
0b01101111 //9
uint8_t
count = 0;
uint16_t
u16Tmp;
//initialize the SPI with a slow ~1MHz clock
SPI.begin();
SPI.beginTransaction( SPISettings( 1000000, MSBFIRST, SPI_MODE0 ) );
//start our class thingy and set the GPIOs to outputs
myPortX.begin();
myPortX.setGPIODir(0xffff); //all ports outputs
//once a second, send a new pattern to port A
//should count from 0-9
while( 1 )
myPortX.setGPIO( (uint16_t)(grSegments[count++]) ); //if this doesn't light segs comment this line out...
//myPortX.setGPIO( (uint16_t)(grSegments[count++] << 8) ); //...and try this one instead
//bump count
if( count == 10 )
count = 0;
//simple 1-sec delay between counts
}//while
}//setup
}//loop
This compiles and generates promising signals on the SPI but I don't have your setup nor the port expander to test with so it may be worthless...
Also, you should really have 330R resistors on each segment pin, not on the CC side.
