how to akes a HTTP connection to the server on yun?
wifishiled:
client.connect(server, 80);
but how to do it on yun?
zixzixzix:
wifishiled:
You don't. There is no http server on the Atmel/sketch part of the Yun, the WiFi/Ethernet is only available on the MIPS/Linin (Linux) part of the Yun.
Ralf
I know that.
But I do not know how to do it in Linux.
zixzixzix:
I know that.
Well, what programming language/software are you using? What server are you trying to use? From where?
I understand that you aren't likely a native English speaker (neither am I) but you need to be a bit more detailed in your description in that case if you think you do not find the right words...
Ralf
server?tcp.lewei50.com post?9960
JSON
"method": "update",
"gatewayNo": "",
"userkey": "userkey"
I am sorry for my English.
I just want to sent JSON to server.
So that I can keep a TCP connect.
Could i use 'curl' to do that?
or i should use python?
