how to analogread while free running mode?
hi
i'm using the fht library ArduinoFHT - Open Music Labs Wiki for analysing an audio signal with my arduino mega.
in addition i'd like to analyse the signal send through a lowpass filter by using analogread().
after setting the adc to free running mode analogread() causes a crash.
setting back ADCSRA bevore analogread() dosen't help.
has anybody an idea? i don't like to have to use a second arduino only for reading the signal.
Please post your code. How are we supposed to help without it? Guess?
How to use this forum
crash at: analogRead(A11)
if i move analogRead(A11) in front of ADCSRA = 0xe7, then the arduino crashes at ADCSRA = 0xe7.
#include <FHT.h>
  ADCSRA = 0xe7; // set the adc to free running mode
  ADMUX = 0x45; // use adc5
  DIDR0 = 0x20; // turn off the digital input for adc5
  sampleInput();
  pinMode(A11, INPUT);
  analogWrite(45,analogRead(A11));
void sampleInput() {
  cli();  // UDRE interrupt slows this way down on arduino1.0
  for (int x=0; x<FHT_N; x++) {
    while(!(ADCSRA & 0x10)); // wait for adc to be ready
    ADCSRA = 0xf5; // restart adc
    byte m = ADCL; // fetch adc data
    byte j = ADCH;
    int k = (j << 8) | m; // form into an int
    k -= 0x0200; // form into a signed int
    k <<= 6; // form into a 16b signed int
    fht_input[x] = k; // put real data into bins
  sei();
  fht_window(); // window the data for better frequency response
  fht_reorder(); // reorder the data before doing the fht
  fht_run(); // process the data in the fht
  fht_mag_lin();
com_:
Could you define "crashes" for us? Did you get the Blue Screen of Death?
when it crashes the execution of the code stops. you only can push the reset button or connect the arduino via usb to the pc
Why are you trying to do an analogRead and use free-running mode? Aren't they mutually exclusive?
i do not exactly know, what the free-running mode does, but i need it for using hfl. and i'd like to read an analog signal.
when i toggle free-running mode, analogread() dosen't cause a crash, but the hfl library dosen't work correctly.
if it's mutually exclusive, is there an equivalent way to read an analog input in free-running mode?
Free running mode means the ADC is constantly taking readings, and calling an interrupt routine to handle them. Do you have such an interrupt routine?
i think this is handled by sampleInput() and not by an interrupt.
i've tried to take over some code to replace analogread(), but i read a constant 2,5V at pin 3, even if i connect it to ground or 5V.
ADMUX = 0x43; // use adc3
delayMicroseconds(200);
byte j = ADCH;
int output = (j << 8) | m; // form into an int
sei();
no, now it works :slight_smile: the cable was broken :confused: thanks for the help :slight_smile:
The broken cable crashed the Arduino? OK.
no no :smiley: the analogread() while free-running mode crashed it. the constant 2,5V at pin 3 were caused by the broken cable. i solved the problem by replacing analogread() with the code from my last post
