I have a lamp that works with an adaptor 230v -> 4V 3W 0.75A
You can just unplug the adapter as you can see in the picture(i'm assuming that the biggest pin is the positive??). I would like to connect it to my arduino so I can control it usinng wifi or IRremote.... Etc. Does anyone know how I can connect 0.75Amps to an arduino uno?
If the lamp uses dc you can use a n channel mosfet with an externel power source but if it uses ac i can not help you since i am not an expert in electronics
Then cut the -ve and as NewStudent says, bung an n-mosfet in there with the mosfet source pin to the -ve going back to the adapter and the mosfet drain pin going to the lamp. Then the gate of the mosfet goes to an Arduino pin for control.
EDIT... NB: so we're both saying, the power supply still stays in play. You can't power 750mA from the Arduino itself, but you can control the external power easily.
The labelling is a bit confused, it says primary and secondary, yet the output voltage has a DC symbol...
I presume its a SMPS with DC output, and its got the double-insulated symbol so it should be fully
isolated (and its a not a chinese cheapy, so it probably is fully isolated).
