Hi Everyone,
I have been working on getting some motors to work through H-bridges and managed to with this code.
// initialise motors
int enA = 3; // Motor 1
int in1 = 4;
int in2 = 2;
int enB = 5; // Motor 2
int in3 = 8;
int in4 = 7;
int enC = 11; // Motor 3
int in5 = 12;
int in6 = 13;
int enD = 6; // Motor 4
int in7 = 9;
int in8 = 10;
pinMode(enA, OUTPUT); // set the outputs for motors
pinMode(enB, OUTPUT);
pinMode(enC, OUTPUT);
pinMode(enD, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
pinMode(in5, OUTPUT);
pinMode(in6, OUTPUT);
pinMode(in7, OUTPUT);
pinMode(in8, OUTPUT);
void motorLoop(){
// setting the direction to turn and speed
digitalWrite(in1, HIGH); // Motor 1
digitalWrite(in2, LOW);
digitalWrite(in3, HIGH); // Motor 2
digitalWrite(in4, LOW);
digitalWrite(in5, HIGH); // Motor 3
digitalWrite(in6, LOW);
digitalWrite(in7, HIGH); // Motor 4
digitalWrite(in8, LOW);
// Set the speed for the Motors
analogWrite(enA, 1);
analogWrite(enB, 20);
analogWrite(enC, 100);
analogWrite(enD, 200);
motorLoop();
However I am trying to turn the data into an array and have hit some issues.
I have never tried creating arrays with Digital inputs but have with Analog ones.
Here is a link to my project on (TinkerCAD) Login | Tinkercad
As you can see by this code I have tried to setup the enable inputs which show no errors but I am struggling setting up the OUTPUT and Speed that the motors rotate at.
// Motor 1
int in1 = 4;
int in2 = 2;
// Motor 2
int in3 = 8;
int in4 = 7;
// Motor 3
int in5 = 12;
int in6 = 13;
// Motor 4
int in7 = 9;
int in8 = 10;
// Array of PWM's
byte pwms[] = {3,5,6,11};
byte numberPwms = 4;
for(byte i = 0; i <= numberPwms; i++){
pinMode(pwms(OUTPUT));
void motorLoop(){
for(byte i = 0; i < numberPwms; i++){
analogWrite(pwms(200));
motorLoop();
Any help with this would be greatly appreciated ![]()
