Hi there,
I'm a bit of a n00b, and I'm working on my first RTC project. I'm using an Arduino for this.
What's the basic process to get this thing hooked up and telling time?
Hi there,
Looks like a great post.
I’ve never used the 2-wire interface before. Which pins on the RTC module to I route to the Arduino?
I’ve got SQW, SCL, and SDA.
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1167945152/0
maybe you can collate all that and make us a proper tutorial for the "Playground" wiki ? :)
D
Excellent, figured it all out.
I'll do what I can to post a nice walkthrough in the wiki.
Thanks for your help!
excellent! You're all signed up to be the forum's DS1307 expert. :)
Haha, we'll see about that.
My last issue if you have any insight: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1186877284/0
...but I can't get it to print out an integer to the LCD. It puts a solid black box. Characters work just fun, and I tried to cast it (char)number_variable, but it just doesn't seem to work.
Just add '0' (ASCII zero) to your integer, to convert the number to ASCII, like this:
LCD_Out(4 + '0')
(LCD_Out() might be a routine that "prints" a single ASCII character to the LCD.)
BTW, on a related topic, I used the DS1302 RTC in a project recently. It uses the same data register format as the DS1307. (The 12/24 hour flag in the Hours register has a different value, otherwise the two data formats are identical.) Feel free to take a peek at it if you think it might help you handle the DS1307.
http://www.mindspring.com/~tom2000/Projects/AI-1_Remote/AI-1_Remote.html
TJ
