How to assign JSON payload to buffer
I'm new both both to Arduino and C++. Here's a template that I customized to send a JSON payload via MQTT.
#define WARN Serial.println
#define MQTTCLIENT_QOS2 1
#include <SPI.h>
#include <Ethernet.h>
#include <IPStack.h>
#include <Countdown.h>
#include <MQTTClient.h>
#include <Thermistor.h>
Thermistor temp(0);
int arrivedcount = 0;
void messageArrived(MQTT::MessageData& md)
MQTT::Message &message = md.message;
Serial.print("Message ");
Serial.print(++arrivedcount);
Serial.print(" arrived: qos ");
Serial.print(message.qos);
Serial.print(", retained ");
Serial.print(message.retained);
Serial.print(", dup ");
Serial.print(message.dup);
Serial.print(", packetid ");
Serial.println(message.id);
Serial.print("Payload ");
Serial.println((char*)message.payload);
EthernetClient c; // replace by a YunClient if running on a Yun
IPStack ipstack(c);
MQTT::Client<IPStack, Countdown, 50, 1> client = MQTT::Client<IPStack, Countdown, 50, 1>(ipstack);
byte mac[] = { 0x00, 0x11, 0x22, 0x33, 0x44, 0x55 }; // replace with your device's MAC
const char* topic = "arduino-sample";
void connect()
char hostname[] = "iot.eclipse.org";
int port = 1883;
Serial.print("Connecting to ");
Serial.print(hostname);
Serial.print(":");
Serial.println(port);
int rc = ipstack.connect(hostname, port);
if (rc != 1)
Serial.print("rc from TCP connect is ");
Serial.println(rc);
Serial.println("MQTT connecting");
MQTTPacket_connectData data = MQTTPacket_connectData_initializer;
data.MQTTVersion = 3;
data.clientID.cstring = (char*)"arduino-sample";
rc = client.connect(data);
if (rc != 0)
Serial.print("rc from MQTT connect is ");
Serial.println(rc);
Serial.println("MQTT connected");
rc = client.subscribe(topic, MQTT::QOS2, messageArrived);
if (rc != 0)
Serial.print("rc from MQTT subscribe is ");
Serial.println(rc);
Serial.println("MQTT subscribed");
Ethernet.begin(mac);
Serial.println("MQTT Hello example");
connect();
MQTT::Message message;
int temperature = temp.getTemp();
if (!client.isConnected())
connect();
arrivedcount = 0;
// Send and receive QoS 1 message
** char charBuf[100]= "Hi";**
** char buf[100];**
** String val = "{";**
** val+="\n";**
** val+=""deviceID": "Arduino01",";**
** val+="\n";**
** val+=""temperature (F)": ";**
** val+=temperature;**
** val+="\n";**
** val+="}";**
** val.toCharArray(charBuf,100);**
** strcpy(buf, "Hello");**
** message.qos = MQTT::QOS1;**
** message.retained = false;**
** message.dup = false;**
__ message.payload = (void*)buf;__
message.payloadlen = strlen(buf)+1;
int rc = client.publish(topic, message);
while (arrivedcount == 0)
Serial.println("Waiting for Temperature Reading");
client.yield(5000);
delay(10000);
I'm trying to assign the JSON payload to "buf" but unless it's a string like "Hello" for strcpy, I'm unable to send anything in the payload.
For example,
if I do strcpy(buf, charBuf); nothing shows up in the payload.
Thanks! for any guidance.
You only need 1 buffer, get rid of the second one, and definitely get rid of the String class. Try this instead of all those string lines:
sprintf( buf, "{\n\"deviceID\": \"Arduino01\",\n\"temperature (F)\": %d\n}", temperature );
Should put the relevant data into buf.
Thanks for the tip! I tried it but it didn't seem to add to the payload:
Here's my code where I added sprintf
   connect();
 arrivedcount = 0;
 // Send and receive QoS 0 message
 char buf[200];
// String val = "{";
//        val+="\n";
//        val+="\"deviceID\": \"Arduino01\",";
//        val+="\n";
//        val+="\"temperature (F)\": ";
//        val+=temperature;
//        val+="\n";
//        val+="}";
// val.toCharArray(charBuf,100);
 //strcpy(buf, "Temperature is");
   client.yield(5000);
 delay(10000);
This is the result in the serial monitor:
IOT Temperature Demo
Connecting to iot.eclipse.org:1883
MQTT connecting
MQTT connected
MQTT subscribed
However if I changed the code back to strcpy:
   connect();
 arrivedcount = 0;
 char buf[200];
//        val+="\n";
//        val+="\n";
//        val+="\n";
//        val+="}";
 //sprintf( buf, "{\n\"deviceID\": \"Arduino01\",\n\"temperature (F)\": %d\n}", temperature );
   client.yield(5000);
 delay(10000);
Here's the result in the serial monitor I see in the payload:
OT Temperature Demo
MQTT connecting
MQTT connected
MQTT subscribed
Message 1 arrived: qos 1, retained 0, dup 0, packetid 1
Payload Temperature is
Message 1 arrived: qos 1, retained 0, dup 0, packetid 2
Thoughts? Ideas?
Thanks!
#7 below:
http://forum.arduino.cc/index.php/topic,148850.0.html
Modified formatting as suggested.
Any ideas? Tips or alternatives? on the original issue.
Thanks!
Any ideas?
I have the idea that you should Serial.print() buf, to make sure it contains what you think it should.
I have the idea that you should make sure that you can actually send a packet of the size you are trying to.
It isn't necessary to actually send the NULL terminator, it the device on the other end knows that the data is a string. Stop adding one to the length.
