I am trying to control multiple servo's with its position and velocity. But i am not getting how to use the var speed library to control the velocity of the motors also. Currentely i'm trying below program without any success.
ServoSequence
Reads an analog input, and plays different servo sequences depending on the analog value
This example code is in the public domain.
#include <VarSpeedServo.h>
VarSpeedServo myservo1, myservo2, myservo3;
const int servoPin1 = 6; // the digital pin used for the servo
// sequences are defined as an array of points in the sequence
// each point has a position from 0 - 180, and a speed to get to that position
servoSequencePoint slow[] = {{100,20},{20,20},{60,50}};
servoSequencePoint twitchy[] = {{0,255},{180,40},{90,127}};
const int analogPin = A0;
// the setup routine runs once when you press reset:
myservo1.attach(servoPin1);
myservo2.attach(8);
myservo3.attach(5);
// the loop routine runs over and over again forever:
// read the input on analog pin 0:
int sensorValue = analogRead(analogPin);
if (sensorValue > 200) {
myservo1.sequencePlay(slow, 3); // play sequence "slowHalf" that has 3 positions, loop and start at first position
myservo2.sequencePlay(slow,3);
delay(2); // delay in between reads for analogin stability
Here whenever i assign the slow list value inside the loop than it don't works. It seems like its value has to be declared globally, than only it works. How can i assign the servosequencePoint value inside the loop, so that each time i can change the parameters and than move the servo in different order?
I also tried to modify the SweepTwoServo example from the VarSpeedServo library, but seems like i can't use it for more than two servo, so i'm trying this servoSequence program. But i'm not being able to modify it further to make it work properly.
