how to assign value to some non-array parameters in a FOR loop
Hello,
First of all, I'm new to programming C++.
I'm not sure how to ask my question. Suppose we have the following parameters with a constant pattern:
RemoteXY.edit_D_L_1;
RemoteXY.edit_D_L_2;
RemoteXY.edit_D_L_3;
RemoteXY.edit_D_L_4;
RemoteXY.edit_D_L_n;
For some reason I cannot change them to array.
Is there any way I can assign value to them in a FOR loop?
No. Variable names are meaningless and not available after compilation so you can't just concatenate a number with a variable name and create a new variable if that is what you had in mind
Cannot or do not know how to ?
Yes.
First, if (and only if) they are consecutive in the RemoteXY struct, you CAN make them an array
struct
  type edit_D_L_1;
  type edit_D_L_2;
  type edit_D_L_3;
  type edit_D_L_4;
} RemoteXY;
Is the same as:
struct
  type edit_D_L[4];
} RemoteXY;
If they are not consecutive, then you can make an array of pointers to those struct variables:
struct
  type edit_D_L_1;
  type edit_D_L_2;
  type edit_D_L_3;
  type edit_D_L_4;
} RemoteXY;
type * const arrayOfVariables[] =
  &RemoteXY.edit_D_L_1,
  &RemoteXY.edit_D_L_2,
  &RemoteXY.edit_D_L_3,
  &RemoteXY.edit_D_L_4,
Example here: 9MCQ6a - Online C++ Compiler & Debugging Tool - Ideone.com
if the value of constants is related to the symbol name I would use a script to generate the code
constant int D_L_00 =  0;
constant int D_L_01 =  1;
constant int D_L_02 =  2;
constant int D_L_03 =  3;
constant int D_L_04 =  4;
constant int D_L_05 =  5;
constant int D_L_06 =  6;
constant int D_L_07 =  7;
constant int D_L_08 =  8;
constant int D_L_09 =  9;
constant int D_L_10 = 10;
# temperature sensor
awk '
BEGIN {
    for (n = 0; n < 11; n++)
        printf "constant int D_L_%02d = %2d;\n", n, n
symbol names (e.g. D_L_4) are unknown during execution. variables are replaced with addresses and constant with their values
