how to aviod void loop() updating only once per second?
Hello all, I'm new to programming and I got stuck with my first more complex project. I have the following code but everything I put in void loop() is updating once per second if Sw1 is high. I assume that the ONE_HZ_SW is responsible for this behaviour. How should I avoid that? I need other things in the loop to run faster.
Thank you!
#include <Wire.h> // specify use of Wire.h library.
#define ONE_HZ_SW 2 // one Hz square wave from Ds1307
#define blinkPin 13
#define Sw0 4
#define Sw1 5
#define Sw2 6
  Wire.begin(); // join i2c bus (address optional for master)
  Serial.begin(57600);
  digitalWrite(blinkPin, 0);
  pinMode(ONE_HZ_SW, INPUT_PULLUP);
  pinMode(Sw0, INPUT_PULLUP);  // for this use a slide switch
  pinMode(Sw1, INPUT_PULLUP);  // N.O. push button switch
  pinMode(Sw2, INPUT_PULLUP);  // N.O. push button switch
  // wait or HIGH
  while(!digitalRead(ONE_HZ_SW)) {
  Wire.beginTransmission(0x68);
  Wire.write(0);  // location pointer
  Wire.endTransmission();
  Wire.requestFrom(0x68, 7); // send 7 bytes
  byte secs = Wire.read();
  byte mins = Wire.read();
  byte hrs = Wire.read();
  byte day = Wire.read();
  byte date = Wire.read();
  byte month = Wire.read();
  byte year = Wire.read();
  // hours, minutes, seconds
  Serial.print("The time is ");
  if (hrs < 10) Serial.print("0");
  Serial.print(hrs,HEX);
  Serial.print(":");
  if (mins < 10) Serial.print("0");
  Serial.print(mins, HEX);
  Serial.print(":");
  if (secs < 10) Serial.print("0");
  Serial.println(secs, HEX);
  // use DD-MM-YYYY
  Serial.print("The date is ");
  if (date < 10) Serial.print("0");
  Serial.print(date, HEX);
  Serial.print("-");
  if (month < 10) Serial.print("0");
  Serial.print(month,HEX);
  Serial.print("-");
  Serial.print("20");
  if (year < 10) Serial.print("0");
  Serial.println(year, HEX);
  if (!(digitalRead(Sw0))) set_time(); // hold the switch to set time
  while(digitalRead(ONE_HZ_SW)) {
  } // wait or LOW
  toggle(blinkPin);
// toggle the state on a pin
void toggle(int pinNum)
  int pinState = digitalRead(pinNum);
  pinState = !pinState;
  digitalWrite(pinNum, pinState);
void set_time()   {
  byte minutes = 0;
  byte hours = 0;
  while (!digitalRead(Sw0))  // set time switch must be released to exit
    while (!digitalRead(Sw1)) // set minutes
      minutes++;
      if ((minutes & 0x0f) > 9) minutes = minutes + 6;
      if (minutes > 0x59) minutes = 0;
      Serial.print("Minutes = ");
      if (minutes <= 9) Serial.print("0");
      Serial.println(minutes, HEX);
      delay(400);
    while (!digitalRead(Sw2)) // set hours
      hours++;
      if ((hours & 0x0f) > 9) hours =  hours + 6;
      if (hours > 0x23) hours = 0;
      Serial.print("Hours = ");
      if (hours <= 9) Serial.print("0");
      Serial.println(hours, HEX);
      delay(400);
    Wire.beginTransmission(0x68); // activate DS1307
    Wire.write(0); // where to begin
    Wire.write(0x00);          //seconds
    Wire.write(minutes);          //minutes
    Wire.write(hours);    //hours (24hr time)
    Wire.write(0x01);  // Day 01-07
    Wire.write(0x9);  // Date 0-31
    Wire.write(0x5);  // month 0-12
    Wire.write(0x16);  // Year 00-99
    Wire.write(0x10); // Control 0x10 produces a 1 HZ square wave on pin 7.
Remove the code. Before doing that, though, you might explain what is connected to the ONE_HZ_SW pin and why the code is there in the first place.
  // wait or HIGH
Comment out the last 2 lines. Is that fast enough for you ?
For example I need to count the millis between the ONE_HZ_SW pulses but everywhere I put the code inside the void loop() Sw3 is read once per second and gives the elapsed value 0
  if (!digitalRead(ONE_HZ_SW))
    start=millis();
  if (!digitalRead(Sw3))
    finished=millis();
    lcd.clear();
    lcd.setCursor(0,1); //Start at character 0 on line 1
    lcd.print(elapsed);
  elapsed=finished-start;
This is a wild guess, but if ONE_HZ_SW does what it seems to then there will be 1000 milliseconds between the pulses.
UKHeliBob:
I need to have a stopwatch to count at millis level with the precision of the RTC. When I press the Sw3, I need to have the last date and time from the RTC plus the millis from the last second pulse til the Sw3 push.
First take out the while loop that waits for a pulse. Did you comment out the lines that I suggested ?
Then you can implement a timing mechanism using millis() to give greater resolution than 1 second.
By all means periodically refresh the time from the RTC, but do it every minute and don't do it by putting in a blocking while loop.
UKHeliBob:
I am not at my workshop now but I will try out later.
UKHeliBob:
Could I change the 'while' with 'if' so that the loop will constantly check and execute the time code only when ONE_HZ_SW pulses?
Thank you a lot for the clarifications!
Sure. Just make sure that you are looking when the pulse happens.
PaulS:
Is it possible to achieve this using interrupts?
Edit: if I count the millis from one pulse and if millis 990 wait for the pulse 20 milis? But I think this will be too complicated for me to write...
paulus_v:
Of course. That is what interrupts are for. Just be sure that you understand what happens when the interrupt happens, what you can, and can not, do in the interrupt handler, and where control returns to when the interrupt handler is done.
paulus_v:
I don't know why you are so obsessed with the 1 second timer pulse from the RTC.
Let loop() run freely and check each time through whether the "start timing" button has become pressed. not if it is pressed. When you detect that save the time from milli() and start looking for the "stop timing" button to become pressed. It can be the same button if you like. When you detect that, subtract the start value of millis() from the current value of millis() and you have the elapsed time in milliseconds. Format the value how you would like and display it.
All other stopwatch actions such as lap timing and split timing use the same technique.
UKHeliBob:
Yes I am obsessed, but for a reason.
I do not need a simple stopwatch/ to count the time between 2 button presses but I need, with only one button press, to get the RTC actual time with hundredths of a second precision.
And I will use a more precise temperature compensated RTC instead of the DS1307 when it arrives.
How long does it take to read the current time from the RTC and is the time taken consistent ?
What I have in mind is to let loop() run freely monitoring the state of the button pin. When a button press is detected request the current time from the RTC and apply a correction for the read time if required.
UKHeliBob:
The problem is that the current time from the RTC has only a 'seconds' resolution, but I need to have the hundredths of seconds count for the moment when the button is pressed. The precision of the 'hundredths' is not critical (could be counted by the arduino) but I need it.
My options are:
  1. to find a millisecons resolution RTC;
  2. try to use interrupts to handle the RTC square wave output;
  3. use an arduino only for the above sketch to output e.g. a one second high/ one second low to be put in an other arduino to deal with the rest of the things.
paulus_v:
Yes, it is possible and easy. Here is a sample ISR from one of my clock programs:
void rtc_pps_handler()
  thisRtcTick = millis();
  rtc_pps_flag = true;  //inform main program that a pulse has been received
In loop() you test for the rtc_pps_flag, and then reset it. That will tell you when a second has begun. After that, subtracting thisRtcTick from millis() will give you the milliseconds resolution. It will be accurate regardless of delays in responding to the interrupt in loop().
aarg:
Many thanks!
I will give it a try later today.
paulus_v:
Many thanks!
The IDE docs for interrupts are here: attachInterrupt() - Arduino Reference. Make sure you choose the correct pulse polarity, RISING or FALLING.
aarg:
I have already found the docs. I only need time to read and learn everything. The pulse in my case is FALLING.
