WiFi.mode(WIFI_STA); // not AP-mode station-mode which means connect to an AP
As far as I understand WiFi the only thing you can do with wifi is let the ESP act as the Accesspoint itself or connect the ESP to an accesspoint. My code connects to an accesspoint.
scan for available WiFis (self-explaining name of the function
analyse which Wifi has the strongest RSSI-value
connect to the Wifi with the strongest RSSI-value
function has a self-explaining name
check two IO-pins beeing low / high which indicates if ESP32 is supplied by wallplug A or wallplug B or if it is running on battery sending a status-message to the internetservice pushsafer
If you want peer to peer communication without the need for an access-point
use ESP-NOW
Demo-code for send / receive data with ESP-NOW
// WARNING !! Trying to adapt this ESP32-code using ESP-NOW to a ESP8266 is a big hassle
// as the ESP8266-ESP-NOW-library works very differently using other functions etc.
// for coding with an ESP8266 start with a code that is written for ESP8266 DON'T try to adapt an ESP32-code
//WiFiLib and Esp-NowLib espnowlib
#include <WiFi.h> // ESP32 needs "WiFi.h" ESP8266 needs "ESP8266WiFi.h"
#include <esp_now.h> // ESP32 needs "esp_now.h" ESP8266 needs "espnow.h" do you recognize the difference?
#define CHANNEL 0
boolean gb_SerialOutput_enabled = true;
using MacAdr = uint8_t[6];
// the code must know all receivers MAC-adresses that THIS boards wants to send data to
MacAdr ESP_NOW_MAC_adrOfRecv1 { 0x18, 0xFE, 0x34, 0xCF, 0x1F, 0xF4 };
//ESP_NOW_MAC_adrTimeRcv[] = { 0x18, 0xFE, 0x34, 0xCF, 0x1F, 0xF4 };
MacAdr ESP_NOW_MAC_adrOfRecv2 { 0x24, 0x0A, 0xC4, 0x02, 0xBC, 0x20 };
MacAdr ESP_NOW_MAC_adrOfRecv3 { 0x24, 0x6F, 0x28, 0x22, 0x62, 0xFC };
MacAdr SendersOwnMacAdress { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
void SetupOwnMacAdress(){
memcpy (SendersOwnMacAdress, ESP_NOW_MAC_adrOfRecv3, sizeof(SendersOwnMacAdress) );
esp_now_peer_info_t peerInfo;
void RegisterPeer(const MacAdr &MyMac_Adress_array) {
memcpy(peerInfo.peer_addr, MyMac_Adress_array, sizeof(peerInfo.peer_addr) );
peerInfo.channel = 0;
peerInfo.encrypt = false;
if (esp_now_add_peer(&peerInfo) != ESP_OK)
{ if (gb_SerialOutput_enabled)
{ Serial.println("Failed to add peer"); }
return;
//nbt nonblockingtimer
boolean TimePeriodIsOver (unsigned long &expireTime, unsigned long TimePeriod) {
if ( currentMillis - expireTime >= TimePeriod )
expireTime = currentMillis; // set new expireTime
return true; // more time than TimePeriod) has elapsed since last time if-condition was true
else return false; // not expired
unsigned long BlinkTimer = 0;
const int OnBoardLED = 2;
unsigned long SendDataTimer = 0;
// pslib pstringlib
//#include <PString.h> // the use of PString avoids code-malfunction like Strings can do
#include <SafeString.h>
char TestESP_CmdStr_AoC[64];
//PString TestESP_CmdStr_PS(TestESP_CmdStr_AoC, sizeof(TestESP_CmdStr_AoC) );
createSafeString(TestESP_CmdStr_PS,64);
// pfndt
void PrintFileNameDateTime() {
Serial.print("Code running comes from file "); Serial.println(__FILE__);
Serial.print("compiled "); Serial.print(__DATE__); Serial.print(" "); Serial.println(__TIME__);
// pma pwma
void PrintWiFiMacAdress() {
char MacAdr_AoC[18]; //suffix _AoC for easier remembering variable-type is ArrayOfChar
char HexByteDigits[3];
for (uint8_t i = 0; i < 18; i = i + 1){
MacAdr_AoC[i] = WiFi.macAddress()[i];
MacAdr_AoC[17] = 0; // zero to terminate the string
Serial.print("ESP Board Wifi.macAddress: ");
Serial.println(MacAdr_AoC);
Serial.println("copy the line below and replace the '#' with variablename of your choice");
Serial.print("uint8_t #[] = { ");
for (uint8_t i = 0; i < 16; i = i + 3)
HexByteDigits[0] = MacAdr_AoC[i];
HexByteDigits[1] = MacAdr_AoC[i + 1];
HexByteDigits[2] = 0; // zero for terminating the string
Serial.print("0x");
Serial.print(HexByteDigits);
if (i < 14) Serial.print(", ");
Serial.println(" };");
// espnowmsg espnowbytes enbytes espstruc
// Structure example to send data. Must match the receiver structure
typedef struct MyESP_NOW_Data_type {
char MyESP_NOW_SenderID_AoC[16];
char MyESP_NOW_StatusMsg_AoC[64];
int MyESP_NOW_Int;
float MyESP_NOW_Float;
} MyESP_Data_type;
MyESP_NOW_Data_type ESP_Data_Received;
MyESP_NOW_Data_type ESP_Data_ToSend;
// Init ESP Now with restart in case something went wrong
void InitESPNow() {
{ if (esp_now_init() == ESP_OK)
{ Serial.println("ESPNow Init Success"); }
{ Serial.println("ESPNow Init Failed");
ESP.restart(); //there was an error try again through restarting the board
void ESP_NOW_Setup() {
WiFi.mode(WIFI_STA); //Set device in STA mode to begin with
WiFi.disconnect(); // for strange reasons WiFi.disconnect(); is nescessary to make ESP-NOW work
{ Serial.println("WiFi.mode(WIFI_STA WiFi.disconnect() done");}
InitESPNow(); // Init ESPNow with a fallback logic
esp_now_register_send_cb(OnDataSent);
esp_now_register_recv_cb(OnDataRecv);
RegisterPeer(ESP_NOW_MAC_adrOfRecv1);
RegisterPeer(ESP_NOW_MAC_adrOfRecv2);
RegisterPeer(ESP_NOW_MAC_adrOfRecv3);
void PrintESP_Status(esp_err_t result) {
Serial.print("Send Status: ");
if (result == ESP_OK)
{ Serial.println("sended"); }
else if (result == ESP_ERR_ESPNOW_NOT_INIT)
{ Serial.println("Master ESPNOW not Init."); }
else if (result == ESP_ERR_ESPNOW_ARG)
{ Serial.println("Master Invalid Argument"); }
else if (result == ESP_ERR_ESPNOW_INTERNAL)
{ Serial.println("Master Internal Error");}
else if (result == ESP_ERR_ESPNOW_NO_MEM)
{ Serial.println("Master ESP_ERR_ESPNOW_NO_MEM"); }
else if (result == ESP_ERR_ESPNOW_NOT_FOUND)
{ Serial.println("Master Peer not found."); }
{Serial.println("Master Not sure what happened"); }
void SendData() {
{ Serial.println("sendData() Start");}
esp_err_t result;
if(memcmp(ESP_NOW_MAC_adrOfRecv1, SendersOwnMacAdress, sizeof(SendersOwnMacAdress) ) != 0) { // if MAC-Adess is not the own MAC-Adress
result = esp_now_send(ESP_NOW_MAC_adrOfRecv1, (uint8_t *) &ESP_Data_ToSend, sizeof(ESP_Data_ToSend));
// if sending has finished function OnDataSent is called
if(memcmp(ESP_NOW_MAC_adrOfRecv2, SendersOwnMacAdress, sizeof(SendersOwnMacAdress) ) != 0) {
result = esp_now_send(ESP_NOW_MAC_adrOfRecv2, (uint8_t *) &ESP_Data_ToSend, sizeof(ESP_Data_ToSend));
if(memcmp(ESP_NOW_MAC_adrOfRecv3, SendersOwnMacAdress, sizeof(SendersOwnMacAdress) ) != 0) {
result = esp_now_send(ESP_NOW_MAC_adrOfRecv3, (uint8_t *) &ESP_Data_ToSend, sizeof(ESP_Data_ToSend));
// callback-function that is executed when data was send to another ESP32-board
// parameter status contains info about the success or fail of the transmission
void OnDataSent(const uint8_t *Receivers_mac_addr, esp_now_send_status_t status) {
char Receivers_macStr[18];
snprintf(Receivers_macStr, sizeof(Receivers_macStr), "%02x:%02x:%02x:%02x:%02x:%02x",Receivers_mac_addr[0], Receivers_mac_addr[1], Receivers_mac_addr[2], Receivers_mac_addr[3], Receivers_mac_addr[4], Receivers_mac_addr[5]);
Serial.print("callback-OnDataSent ");
Serial.print("ESP32-Board Last Packet Sent to: ");
Serial.println(Receivers_macStr);
Serial.print("ESP32-Board1 Last Packet Send Status: ");
Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Failed");
// callback-function that is executed when a ESP-NOW-Message is received
void OnDataRecv(const uint8_t *Senders_mac_addr, const uint8_t *receivedBytes, int NoOfreceivedBytes) {
memcpy(&ESP_Data_Received, receivedBytes, sizeof(ESP_Data_Received));
Serial.println("callback-OnDataRecv ");
char Senders_macStr[18]; //MAC-Adress of sender
snprintf(Senders_macStr, sizeof(Senders_macStr), "%02x:%02x:%02x:%02x:%02x:%02x", Senders_mac_addr[0], Senders_mac_addr[1], Senders_mac_addr[2], Senders_mac_addr[3], Senders_mac_addr[4], Senders_mac_addr[5]);
Serial.print("received from MAC-Adress");
Serial.println(Senders_macStr);
Serial.println("receievd data:");
Serial.print("SenderID #");
Serial.print(ESP_Data_Received.MyESP_NOW_SenderID_AoC);
Serial.println("#");
Serial.print("StatusMsg #");
Serial.print(ESP_Data_Received.MyESP_NOW_StatusMsg_AoC);
Serial.print("Integer:");
Serial.print(ESP_Data_Received.MyESP_NOW_Int);
Serial.print("Float:");
Serial.print(ESP_Data_Received.MyESP_NOW_Float);
void SetupMessageToSend() {
//1
if(memcmp(ESP_NOW_MAC_adrOfRecv1, SendersOwnMacAdress, sizeof(SendersOwnMacAdress) ) == 0) { // if MAC-Adess1 IS the own MAC-Adress
memcpy(ESP_Data_ToSend.MyESP_NOW_SenderID_AoC, "ESP32-Board1111", sizeof(ESP_Data_ToSend.MyESP_NOW_SenderID_AoC) );
memcpy(ESP_Data_ToSend.MyESP_NOW_StatusMsg_AoC, " I am Board No 1", sizeof(ESP_Data_ToSend.MyESP_NOW_StatusMsg_AoC) );
ESP_Data_ToSend.MyESP_NOW_Int = ESP_Data_ToSend.MyESP_NOW_Int + 1;
ESP_Data_ToSend.MyESP_NOW_Float = 111.111;
//2
if(memcmp(ESP_NOW_MAC_adrOfRecv2, SendersOwnMacAdress, sizeof(SendersOwnMacAdress) ) == 0) { // if MAC-Adess2 IS the own MAC-Adress
memcpy(ESP_Data_ToSend.MyESP_NOW_SenderID_AoC, "ESP32-Board2222", sizeof(ESP_Data_ToSend.MyESP_NOW_SenderID_AoC) );
memcpy(ESP_Data_ToSend.MyESP_NOW_StatusMsg_AoC, " I am Board No 2", sizeof(ESP_Data_ToSend.MyESP_NOW_StatusMsg_AoC) );
ESP_Data_ToSend.MyESP_NOW_Int = ESP_Data_ToSend.MyESP_NOW_Int + 2;
ESP_Data_ToSend.MyESP_NOW_Float = 222.222;
//3
if(memcmp(ESP_NOW_MAC_adrOfRecv3, SendersOwnMacAdress, sizeof(SendersOwnMacAdress) ) == 0) { // if MAC-Adess3 IS the own MAC-Adress
memcpy(ESP_Data_ToSend.MyESP_NOW_SenderID_AoC, "ESP32-Board3333", sizeof(ESP_Data_ToSend.MyESP_NOW_SenderID_AoC) );
memcpy(ESP_Data_ToSend.MyESP_NOW_StatusMsg_AoC, " I am Board No 3", sizeof(ESP_Data_ToSend.MyESP_NOW_StatusMsg_AoC) );
ESP_Data_ToSend.MyESP_NOW_Int = ESP_Data_ToSend.MyESP_NOW_Int + 3;
ESP_Data_ToSend.MyESP_NOW_Float = 333.333;
{ PrintFileNameDateTime(); }
ESP_NOW_Setup();
{ PrintWiFiMacAdress(); }
pinMode(OnBoardLED,OUTPUT);
if ( TimePeriodIsOver(BlinkTimer,500) ) {
digitalWrite (OnBoardLED, !digitalRead(OnBoardLED) );
if ( TimePeriodIsOver(SendDataTimer,2000) ) {
SetupMessageToSend();
SendData();
best regards Stefan
