If you look to my program, I use a delay() outside the loop, but how can I avoid this? I don't want to pause the whole code (and I thought that's what a delay does...)
pinMode (6, INPUT); //1 button
pinMode (2, OUTPUT); //LED 1
pinMode (3, OUTPUT); //LED 2
pinMode (4, OUTPUT); //LED 3
pinMode (5, OUTPUT); //LED 4
unsigned long but1LastPress = 0;
const int buttonPressDelay = 600;
//Read the state of the button
int but1read = digitalRead(6);
//Button 1 is pressed
if ((but1read == HIGH) && ((millis() - but1LastPress) > buttonPressDelay)) {
but1LastPress = millis();
doButton1();
}else if ((but1read == LOW) && ((millis() - but1LastPress) > buttonPressDelay ))
but1LastPress = 0; // reset
void doButton1() {
Blink3Times();
void Blink3Times(){
for (int i=0; i < 3; i++){
for (int j=2; i <= 5; i++){
digitalWrite(j,LOW); //turn off the LEDS
delay(1000); //Wait 1 second
digitalWrite(j,HIGH); //turn on the LEDS
Thanks for the respond, it seems to work but can I add something so you can call the function updateLedState and choose how long they will blink?
const int Led1 = 2; // the pin numbers for the LEDs
const int Led2 = 3;
const int Led3 = 4;
const int Led4 = 5;
const int Led1Interval = 150; // number of millisecs between blinks
const int Led2Interval= 2500;
const int Led3Interval = 4500;
const int Led4Interval = 4500;
const int blinkDuration = 150; // number of millisecs that Led's are on - all three leds use this
byte Led1State = LOW; // used to record whether the LEDs are on or off
byte Led2State = LOW; // LOW = off
byte Led3State = LOW;
byte Led4State = LOW;
unsigned long currentMillis = 0; // stores the value of millis() in each iteration of loop()
unsigned long previousOnBoardLedMillis = 0; // will store last time the LED was updated
unsigned long previousLed_A_Millis = 0;
unsigned long previousLed_B_Millis = 0;
Serial.println("Starting blink without delay test"); // so we know what sketch is running
// set the Led pins as output:
pinMode(Led1, OUTPUT);
pinMode(Led2, OUTPUT);
pinMode(Led3, OUTPUT);
pinMode(Led4, OUTPUT);
// Notice that none of the action happens in loop() apart from reading millis()
// it just calls the functions that have the action code
currentMillis = millis(); // capture the latest value of millis()
// this is equivalent to noting the time from a clock
// use the same time for all LED flashes to keep them synchronized
blinkLEDs();
void updateLedState() {
if (Led1State == LOW) {
// if the Led is off, we must wait for the interval to expire before turning it on
if (currentMillis - previousOnBoardLedMillis >= Led1Interval) {
// time is up, so change the state to HIGH
Led1State = HIGH;
// and save the time when we made the change
previousOnBoardLedMillis += Led1Interval;
// NOTE: The previous line could alternatively be
// previousOnBoardLedMillis = currentMillis
// which is the style used in the BlinkWithoutDelay example sketch
// Adding on the interval is a better way to ensure that succesive periods are identical
else { // i.e. if onBoardLedState is HIGH
// if the Led is on, we must wait for the duration to expire before turning it off
if (currentMillis - previousOnBoardLedMillis >= blinkDuration) {
// time is up, so change the state to LOW
Led1State = LOW;
previousOnBoardLedMillis += blinkDuration;
void blinkLEDs() {
// this is the code that actually switches the LEDs on and off
updateLedState();
digitalWrite(Led1, Led1State);
//digitalWrite(led_A_Pin, led_A_State);
//digitalWrite(led_B_Pin, led_B_State);
//digitalWrite(buttonLed_Pin, buttonLed_State);
BramWerbrouck:
Yes just change the value of ledInterval. Or pass a value as a parameter - but then you need to change the function so it uses the parameter rather than the global variable ledInterval.
BramWerbrouck:
If I change te value of ledInterval, it just keeps blinking... Faster or slower, but it is still the same
I thought that is what you were asking for.
If you want the blinking to operate for 10 seconds (say) then the simplest way is to create a boolean variable called blinkInProgress and modify the blink function so it will work when that variable is true - but not if it is false.
When you want the blinking to start change the value to true and start another (separate) millis() timer. When that expires it will change the value back to false.
I tried the code and when I past yours in a new sketch, everything works fine, but when I want to add it to my code, it just do nothing...
boolean blinkState = false;
unsigned long startTime;
void blinkLEDs(unsigned long duration, int FREQUENCY)
static int lastCount = ;
if (millis() - startTime <= duration)
int count = (millis() - startTime) / FREQUENCY;
if ( count != lastCount)
digitalWrite(2, !digitalRead(2));
Serial.println(count);
lastCount = count;
digitalWrite(2, LOW);
blinkState = false;
void longpress() {
unsigned long start_hold = millis(); // mark the time
Serial.println("Please keep on pressing for 5 seconds..");
while (sw_state == LOW) {
if (modus == 1) break; //NO long press in mode_Seconds
sw_state = digitalRead(hold_pin); // read input value
if ((millis() - start_hold) >= HOLD_DELAY){ // for longer than HOLD_DELAY
Serial.println("LONG PRESS ACCEPTED");
if (modus == 0){
iLang = iLang +1;
int iSize = sizeof(lang) / sizeof(lang[0]); //determine the length of the array (buttons)
if (iLang >= iSize) iLang = 0;
EEPROM.write(0, iLang); //Store the chosen language onboard
Serial.print("Language changed to ");
Serial.println(lang[iLang]);
startTime = millis();
blinkState = true;
if (blinkState){
blinkLEDs(3000,250);
ShowLang(iLang);
//Give the position of the Hold_pin number in the array
int len = sizeof(buttons) / sizeof(buttons[0]); //determine the length of the array (buttons)
int wantedval = hold_pin;
int wantedpos;
for (int i=0; i<len; i++) {
if (wantedval = buttons[i]) {
wantedpos = i; //wantedpos = the position of the HOLD button in the arrray of the buttons
break; //break the loop after initialized
justpressed[wantedpos] = 0; //Reset the SHORT PRESS for the hold_pin
void longpress() {
if (modus == 0){
iLang = iLang +1;
blinkState = true;
if (blinkState){
blinkLEDs(3000);
ShowLang(iLang);
int wantedpos;
into
void longpress() {
blinkState = true;
while(blinkState == true) blinkLEDs(3000);
if (modus == 0){
iLang = iLang +1;
ShowLang(iLang);
int wantedpos;
So I changed the IF into a WHILE statement
now it works, but I have another issue:
It is not 1 LED that has to blink but 4! so I added in the blinkState()-function this:
void blinkLEDs(unsigned long duration){
Clear_CornerLEDS();
static int lastCount;
if (millis() - startTime <= duration){
if (count != lastCount){
digitalWrite(3, !digitalRead(3));
digitalWrite(4, !digitalRead(4));
digitalWrite(5, !digitalRead(5));
lastCount = count;
blinkState = false;
What I see is this: they blink very "weak", not on "full power" if you understand what I mean, is there any solution?
//blink LEDs
//Corner LEDs (minutes)
const byte LEDs[] = {2, 3, 4, 5};
const int NUMLEDS = sizeof(LEDs);
// Here is where we define the buttons that we'll use. button "6" is the first, button "9" is the 4th, etc
const byte buttons[] = {6, 7, 8, 9};
#define DEBOUNCE 10 // button debouncer, how many ms to debounce, 5+ ms is usually plenty
// This handy macro lets us determine how big the array up above is, by checking the size
const int NUMBUTTONS = sizeof(buttons);
//track if a button is just pressed, just released, or 'currently pressed'
byte pressed[NUMBUTTONS], justpressed[NUMBUTTONS], justreleased[NUMBUTTONS];
byte previous_keystate[NUMBUTTONS], current_keystate[NUMBUTTONS];
const int HOLD_DELAY = 5000; // Sets the hold delay for the LONG PRESS
int sw_state = HIGH;
const int hold_pin = 6; //pin number for the LONG PRESS
//SETUP PINS
for (byte i=0; i< NUMBUTTONS; i++) {
pinMode (buttons[i], INPUT_PULLUP);
for (byte i=0; i< NUMLEDS; i++) {
pinMode (LEDs[i], OUTPUT);
byte thisSwitch=thisSwitch_justPressed();
switch(thisSwitch){
case 0:
Serial.println("switch 1 just pressed");
doButton1();
case 1:
Serial.println("switch 2 just pressed");
doButton2();
case 2:
Serial.println("switch 3 just pressed");
doButton3();
case 3:
Serial.println("switch 4 just pressed");
doButton4();
void Clear_CornerLEDS(){
for (int i=0;i<=NUMLEDS;i++)
digitalWrite(LEDs[i],LOW);
void Light_CornerLEDS(){
digitalWrite(LEDs[i],HIGH);
void doButton1() {
//do something
void doButton2() {
//do something
void doButton3() {
//do something
void doButton4() {
//do something
void check_switches()
static byte previousstate[NUMBUTTONS];
static byte currentstate[NUMBUTTONS];
static long lasttime;
byte index;
if (millis() < lasttime) {
// we wrapped around, lets just try again
lasttime = millis();
if ((lasttime + DEBOUNCE) > millis()) {
// not enough time has passed to debounce
return;
// ok we have waited DEBOUNCE milliseconds, lets reset the timer
for (index = 0; index < NUMBUTTONS; index++) {
justpressed[index] = 0; //when we start, we clear out the "just" indicators
justreleased[index] = 0;
currentstate[index] = digitalRead(buttons[index]); //read the button
if (currentstate[index] == previousstate[index]) {
if ((pressed[index] == LOW) && (currentstate[index] == LOW)) {
// just pressed
justpressed[index] = 1;
//Long press??
if (sw_state==LOW) longpress();
else if ((pressed[index] == HIGH) && (currentstate[index] == HIGH)) {
justreleased[index] = 1; // just released
pressed[index] = !currentstate[index]; //remember, digital HIGH means NOT pressed
previousstate[index] = currentstate[index]; //keep a running tally of the buttons
byte thisSwitch_justPressed() {
byte thisSwitch = 255;
check_switches(); //check the switches & get the current state
for (byte i = 0; i < NUMBUTTONS; i++) {
current_keystate[i]=justpressed[i];
if (current_keystate[i] != previous_keystate[i]) {
if (current_keystate[i]) thisSwitch=i;
previous_keystate[i]=current_keystate[i];
return thisSwitch; //return the index number (of the array) of which button is pressed
void longpress() {
//if (modus == 0){
//initialize_is_running = true; // keep loop running even though reset_settings_pin is low
blinkState = true;
while(blinkState == true) blinkLEDs(1500,100);
justpressed[6] = 0; //Reset the SHORT PRESS for the hold_pin
void blinkLEDs(unsigned long duration, int FREQUENCY){
Clear_CornerLEDS();
Light_CornerLEDS();
delay(10);
lastCount = count;
blinkState = false;
try to simplify your base code with a Bounce2.h library:
#include <Bounce2.h>
#define NUMBER_OF_SWITCHES 4
Bounce debouncer[NUMBER_OF_SWITCHES];
int oldValue[NUMBER_OF_SWITCHES];
byte switchPin[NUMBER_OF_SWITCHES] = {2,3,4,5}; //<<<<<<<<<<< set your switch pins here
for (int i = 0; i < NUMBER_OF_SWITCHES; i++)
pinMode(switchPin[i],INPUT_PULLUP);
debouncer[i] = Bounce();
debouncer[i].attach(switchPin[i]);
debouncer[i].interval(5);
debouncer[i].update();
int value = debouncer[i].read();
if (value != oldValue[i])
doSomethingWith(i);
oldValue[i] = value;
void doSomethingWith(int pinNumber) // your pin was triggered, so do something with it here...
then blend in what we did earlier... (compiles but not tested)
#define BLINK_DURATION 20000
#define BLINK_FREQUENCY 100
byte ledPin[NUMBER_OF_SWITCHES] = {6,7,8,9};
unsigned long startTime[NUMBER_OF_SWITCHES];
boolean blinkState[NUMBER_OF_SWITCHES];
pinMode(ledPin[i], OUTPUT);
activateLed(i);
if (blinkState[i])
blinkForTime(i, BLINK_DURATION, BLINK_FREQUENCY); //<<<< you could also store Durations and Frequencies in an array e.g.:
//blinkForTime(i, blinkDuration[i], blinkFrequency[i]);
void activateLed(int pin) // your pin was triggered, so do something with it here...
if (!blinkState[pin])
startTime[pin] = millis();
blinkState[pin] = true;
void blinkForTime(int led, unsigned long duration, int frequency)
static int lastCount[NUMBER_OF_SWITCHES];
if (millis() - startTime[led] <= duration)
int count = (millis() - startTime[led]) / frequency;
if ( count != lastCount[led])
digitalWrite(ledPin[led], !digitalRead(ledPin[led]));
lastCount[led] = count;
digitalWrite(ledPin[led], LOW);
blinkState[led] = false;
There seems to be an awful lot of code in Reply #12 if all that is wanted is to read 4 switches and flash some LEDs.
Do you really need any debounce stuff?
The switch code in the Thread planning an implementing a program is much simpler and does not need any explicit debouncing. It has two switches and it does not use arrays although arrays would be a good idea with 4 buttons.
BulldogLowell:
It sounds like you are trying to have 4 buttons with different outputs for long and short button presses... no?
If that is what you want just record millis() when the button changes from high to low (assuming active low) and record it again when the button changes from low to high. Have separate values for each button. Use the difference between the press and release times to decide whether you have a long or a short press (or a press that is just a bounce). That way the same code serves all the purposes. Then you can have action code like
if (buttonApressMills < minMillis) {
// ignore a bounce
else if (buttonApressMillis < longMillis) {
// do the short stuff
else {
// do the long stuff
BulldogLowell:
This is exactly what I need. I'm building a little game for my children. 4 buttons and 4 LEDs...
Every button should have a short press action and a long press action and I need combinations too.. (but 1 & but 2, but 1 & but 3, but 1 & but 4, but 2 & but 3, but 2 & but 4 and but 3 & but 4)
I saw that the buttons work better with debouncing.. That's the reason I used this code, I found it somewhere on the net.. But perhaps you guys have a nicer and better code for doing that?
