how to avoid receiver the Garbled from a CAN BUS device
I received the following CAN BUS DATA, obviously some thing wrong. How to judge the start and finish of the CAN BUS DATA?
Used: GitHub - coryjfowler/MCP_CAN_lib: MCP_CAN Library
#include <mcp_can.h>
#include <SPI.h>
unsigned long int rxId;
unsigned char len = 0;
unsigned char rxBuf[8];
bool displayOnce;
bool displaySend;
bool x;
bool msgInput;
bool idInput;
bool lengthInput;
bool selection;
byte idLength;
char id[10];
char msg[35];
unsigned char byteMsg[9];
int r;
int t;
int y;
int byteLength;
long int byteId;
String command;
#define CAN0_INT 2                              // Set INT to pin 2
 //// MCP_CAN CAN0(10);                               // Set CS to pin 10
MCP_CAN CAN0(9);
  if (CAN0.begin(MCP_ANY, CAN_125KBPS, MCP_8MHZ) == CAN_OK)
    CAN0.setMode(MCP_NORMAL);
    pinMode(CAN0_INT, INPUT);
void loop1()
  if (displayOnce == false) {
    menu();
  while (selection == false)
    if (Serial.available())
      command = Serial.readStringUntil('\n');
      if (command.equals("receive"))
        selection = true;
        loop();
      else if (command.equals("send"))
        selection = true;
        for (int x = 0; x < 50; x++) Serial.println();
        send();
void send()
  sendMenu();
  clear();
  for (int x = 0; x < 1; x++)
  if (byteId > 2048)
    r = 1;
    r = 0;
    Serial.print("id = "); Serial.print(byteId, HEX);
    Serial.print("     length =  "); Serial.print(byteLength);
    Serial.print("     msg =  "); while (t < byteLength)
      Serial.print(byteMsg[t], HEX); Serial.print("  "); t++;
    Serial.println(); Serial.println();  Serial.println("To send , press [enter].");
  while (msgInput = true)
      if (command.equals(""))
        byte sndStat = CAN0.sendMsgBuf(byteId, r, byteLength, byteMsg);
        Serial.println("Message Sent!");
      if (command.equals("C") or command.equals("c"))
        clear();
        t = 0;
        byteLength = "";
        displayOnce = false;
        msgInput = false;
        selection = false;
        loop1();
  while (!digitalRead(CAN0_INT))
    CAN0.readMsgBuf(&rxId, &len, rxBuf);
    Serial.print("FRAME:ID=");
    if ((rxId & 0x80000000) == 0x80000000)
      Serial.print(rxId & 0x1FFFFFFF);
      Serial.print(rxId);
    Serial.print(":LEN=");
    Serial.print(len);
    char msgString[3];
    for (byte i = 0; i < len; i++)
      Serial.print(":");
      snprintf(msgString, 3, "%02X", rxBuf[i]);
      Serial.print(msgString);
        clear();
        selection = false;
        x = false;
        loop1();
  if (digitalRead(CAN0_INT))
    if (x == false)
      clear();
      Serial.println("|||||   Nothing to read   |||||   or    |||||   Can bus not detected    |||||");
      for (int x = 0; x < 12 ; x++)Serial.println();
      x = true;
      clear();
      selection = false;
      x = false;
      loop1();
void clear()
  while (Serial.available())
    char t = Serial.read();
  for (int x = 0; x < 50; x++) Serial.println();      // clear the monitor text
  displayOnce = false;                                //display menu options
void menu()
  delay(750);
  Serial.println(); Serial.println(); Serial.println();
  Serial.println("Type 'receive' to monitor the bus");
  Serial.println("                or");
  Serial.println("Type 'send' to transmit a message");
  Serial.println("Type 'C' to return back to this menu");
  Serial.println(); Serial.println(); Serial.println(); Serial.println();
  displayOnce = true;
  return;
void sendMenu()
  Serial.println("What is the can id?");
  while (idInput == false)
      Serial.readBytesUntil('\n', id, 10);
      unsigned long k;
      char *endptr;
      k = strtol(id, &endptr, 16);
      byteId = k;
      idInput = true;
  Serial.println("How many bytes is the message?");
  while (lengthInput == false)
      byteLength = Serial.parseInt();
      if ((byteLength > 0) && (byteLength < 9))
      lengthInput = true;
  Serial.print("Input the message data"); Serial.print("                  ");
  Serial.print("***NOTE: "); Serial.print("Use the following format:    A1,B2,C3,etc."); Serial.println();
  while (msgInput == false)
      Serial.readBytesUntil(',', msg, 3);
      int z;
      char *endptr;
      z = strtol(msg, &endptr, 16);
      byteMsg[y - 1] = z;
      y++;
    if (y > byteLength )
      idInput = false;
      lengthInput = false;
      msgInput = true;
      y = 0;
[code]
[code]08:49:58.432 -> FRAME:ID=524896627:LEN=73:0C:07:60:04:00:00:02:00:49:73:49:49:FF:FF:4E:0B:0A:00:00:01:58:0A:00:00:0D:01:00:00:E8:03:00:00:00:00:00:00:C5:00:C4:00:C0:00:C1:00:C2:00:C6:00:01:00:00:0F:13:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
08:49:58.672 -> FRAME:ID=524896627:LEN=73:0C:07:60:04:00:00:02:00:49:73:49:49:FF:FF:4E:05:0B:00:00:01:58:0B:00:00:0D:01:00:00:E8:03:00:00:00:00:00:00:C5:00:C4:00:C0:00:C1:00:C2:00:C6:00:01:00:00:05:09:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
08:49:58.944 -> FRAME:ID=524896627:LEN=73:0C:07:60:04:00:00:02:00:49:73:49:49:FF:FF:4E:FF:0C:00:00:01:58:0C:00:00:0D:01:00:00:E8:03:00:00:00:00:00:00:C5:00:C4:00:C0:00:C1:00:C2:00:C6:00:01:00:00:3B:3F:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
08:49:59.200 -> FRAME:ID=524896627:LEN=73:0C:07:60:04:00:00:02:00:49:73:49:49:FF:FF:4E:F9:0C:00:00:01:58:0D:00:00:0D:01:00:00:E8:03:00:00:00:00:00:00:C5:00:C4:00:C0:00:C1:00:C2:00:C6:00:01:00:00:31:35:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
Thanks
Adam
You start by posting your code that produced that output. What library are you using?
blh64:
Thanks,
I modified it.
Yikes.
Ditch the String class. It will just fragment memory and cause you grief.
Read the Serial Input Basics tutorial for how to do it right.
Read the Several Things at the Same Time tutorial to refactor your code. You have loop1() calling send() which calls loop1()....
Also, you should never call loop() directly. It will be repeatedly called after it exits each time.
This
Is an assignment, not a comparison and the evaulation will always evaluate true so the while() will never exit.
I stopped reading the code after that...
blh64:
Yikes.
This
Thank you very much, I'll revise the sketch.
Best.
