I am using atmega2560 chip. I have burnt the bootloader using usbasp programmer.
I am uploading the program into my atmega2560 chip through usb to serial convertor Via Tx, RX & DTR pin. This Tx and Rx pin is only to upload the program into my atmega2560 chip.
My problem is, i have uploaded the code. During power OFF and ON, i am turning ON the LED. I am seeing some delay of 5 - 6 secs during the power ON, after that the LED is turning ON.
Condition1: whenever i connect my serial to usb convertor board and i am power OFF and ON the atmega2560 chip, i am not seeing the Power ON delay.
Condition2: without connecting my serial to usb convertor board and i am powering OFF and ON the atmega chip, i am seeing the delay of 5-6 sec during power ON to turn ON the LED.
Why i have an issue of power ON delay while not connecting the usb to serial convertor? What could be problem. Kindly let us know.
Thanks for the reply. I need a bootloader function. Bootloader code will check for incoming code in the serial port? Whenever i connect my usb to serial convertor, i didnot see that power ON delay. Kindly let me know.
I have bootloader delay of 6 to 8 sec during power ON. Some of the search result showing the bootloader delay will take 1 to 2 secs. Is there any new bootloader which reduces the boot time which can be burnt using usbasb programmer.? Kindly let us know. 1 to 2 secs delay is ok for me.
Thanks.
Thanks for the reply. How to use megacore in my project. I need all arduino functions like delay, uart with 16 Mhz external crystal. Kindly let us know.
With the old bootloader, i tried with rx pin to ground and found there is no delay during Power ON. I understand that bootloader skips the incoming data while grounding the rx pin and goes directly to execute the sketch. Is that correct sir.?
Huh. I don't know; I hadn't heard that before! I looked at the code, and it doesn't mention that feature, nor do I see code that explicitly implements any such thing.
It COULD still be a side effect of what the UART sees when Rx is grounded (essentially a BREAK condition, or perhaps a string of 0 (null) characters.)
It's an interesting idea, though. It COULD be implemented...
