How to blink LEDs in biderectional wireless communication with nRF24L01?
Hello,
I am working on the project where I use two nRF24L01 transmitters for biderectional communication between two Arduino Nano. Each Arduino has a button and a LED. The idea is to make two objects which when ‘notice’ each other, have their LEDs blink and/or piezo speakers buzz. LEDs and piezo have to turn off when buttons are pressed.
The principle of work: transmitters send signal and when they receive responce, LEDs start to shine. You press, then release buttons, LEDs turn off and wait for a minute to turn on again (if only the signal is received).
The problem is that I want both LEDs to blink (not shine) at the same time when the signal is received. However, all my ideas on how I could do this did not work out. How to do that? Also, I would appreciate, if anyone shared their thoughts of how I could replace LEDs with Buzzer / piezo speaker.
Below is my current code.
#include <SPI.h>
#include <RH_NRF24.h>
// Singleton instance of the radio driver
RH_NRF24 nrf24;
int blueLed = 3;
int button = 5;
  pinMode(blueLed, OUTPUT);
  pinMode(button, INPUT);
  while (!Serial)
    ; // wait for serial port to connect. Needed for Leonardo only
  if (!nrf24.init())
    Serial.println("init failed");
  // Defaults after init are 2.402 GHz (channel 2), 2Mbps, 0dBm
  if (!nrf24.setChannel(1))
    Serial.println("setChannel failed");
  if (!nrf24.setRF(RH_NRF24::DataRate2Mbps, RH_NRF24::TransmitPower0dBm))
    Serial.println("setRF failed");
   // Send a message
    uint8_t data[] = "Aloha";
    nrf24.send(data, sizeof(data));
    nrf24.waitPacketSent();
    if(digitalRead(button) == HIGH){
      digitalWrite(blueLed, LOW);
    else{
delay(1);
    // Wait for a message
    uint8_t buf[RH_NRF24_MAX_MESSAGE_LEN];
    uint8_t len = sizeof(buf);
    while (nrf24.waitAvailableTimeout(200) && nrf24.recv(buf, &len)) {
          delay(60000);                   //wait for a minute
        else {
          digitalWrite(blueLed, HIGH);     //otherwise, turn LED on
delay(1);
Any help would be appreciated a lot.
