Hello! I have a curious question about exiting a "for" loop which is driving me a bit nuts. I think I am either using the wrong logic altogether or making a basic error in how I'm approaching this problem.
The code is simple, when you run it and type "H" into the serial monitor, the system is on, when you type "L" the system is off, and when you type "A" the system blinks an LED on pin 13 ten times.
My question is this, when you press "A" and the system is running through the "for" loop to blink the LED ten times, I want to be able to turn off the system by typing "L" and end the loop immediately without waiting for all ten LED blinks.
I have tried "break;" statements, as well as "continue" and "return", but can't seem to figure out the correct flow.
int incoming_byte;
int led_pin = 13;
int power = 0;
pinMode(led_pin, OUTPUT);
// Read the last byte in the serial stream
if (Serial.available() > 0) {
incoming_byte = Serial.read();
if (incoming_byte == 'H') {
power = 1;
if (incoming_byte == 'L') {
power = 0;
if (incoming_byte == 'A') {
blink();
// If the system is on, print the "on" message, otherwise print an "off" message
if (power == 1){
power_on();
else if(power == 0){
Serial.println("------off------");
delay(200);
void power_on(){
// Print a message that the power is on
Serial.println("Power On");
delay(200);
void blink (){
// Blink the LED 10 times
for(int x = 1; x<=10; x++){
digitalWrite(led_pin, HIGH);
delay(400);
digitalWrite(led_pin, LOW);
delay(100);
Serial.println(x);
Boolean blinking = false; // ADDITION
power = 1;
power = 0;
if (blinking == true){ blinking =false}else {blinking=true);// ADDTION
blinking = true;
ADDTION
IF its time to change the state of the LED doit!
END ADDITION
Great, thanks to everyone for your help and quick turnaround, very cool!! I didn't think about using "millis" instead of "delay", which seems to create a state machine of sorts. I will have to wrap my head around that further.
I updated the code based on everyone's feedback, but still have a problem with looping the blink function, perhaps one of you will catch it. I will definitely try again when I am less sleep deprived!
const int ledPin = 13; // LED pin
int ledState = LOW; // Is the LED ON or OFF?
long previousTime = 0; // Store the previous time (in millis)
long timeInterval = 1000; // The time that is allowed to pass (in millis)
int incoming_byte; // The last byte in the serial buffer
int power = 0; // Is the system On or OFF?
boolean blinking = false; // Should the LED be blinking?
Serial.begin(9600); // Enable serial transmission
pinMode(ledPin, OUTPUT); // Initialize Pin 13 for the LED
power = 1;
power = 0;
blinking = !blinking;
blinking = true;
blink();
//Serial.println(x);
if (power == 1){
delay(200);
delay(200);
void blink() {
unsigned long currentTime = millis();
//Serial.println(currentTime - previousTime);
if(currentTime - previousTime > timeInterval) {
previousTime = currentTime;
if (ledState == LOW){
ledState = HIGH;
else {
ledState = LOW;
digitalWrite(ledPin, ledState);
You still have the problem of not handling the serial commands while blinking. That's the only way you'll get it to power off while blinking.
I actually wrote up a sketch for this last night while watching Pawn Stars. I'll try to think to post it later.
I'm always somewhat reluctant to post code as it undermines the pedagogical approach that is popular on this forum. Do you promise that I won't just be doing your homework? LOL
Jimmy60:
This is not for a homework problem, but is instead a personal curiosity. I've had tunnel vision for a bit on this code and wanted to get some outside input. I'm all for struggling through problems, but also fond of seeing how others approach problems with much more efficient code and am able to remember solutions better when asking for help sometimes. Cheers!!
You should have two state variables: the number of blinks so far and the current led status. Every time the state machine executes, you invert led status, and if it says "on", you increment the counter. You probably need also a flag to know whether the blink procedure is "running" or not. At the bottom of loop() you drive the led based on the led status variable.
When does the state machine execute ? This is where millis() comes into play. Study the "blink without delay" example. It shows how to execute actions at specified intervals while letting the program do other stuff (in you case, testing Serial.available()).
When you receive a command through the serial interface you can change the state variables to affect the blinking procedure. For example, you can alter the "running" flag to stop it.
what i see is that you are not reading the serial port when for loop is working so its not going to detect your keys so all you have to do is add serial.read() in the for loop and then apply the condition on serial byte... if it L then raise the value of x to 11 and the loop will break u can simply use break function as well and it will work fine
int incoming_byte;
int led_pin = 13;
int power = 0;
power = 1;
power = 0;
blink();
if (power == 1){
power_on();
delay(200);
void power_on(){
delay(200);
void blink (){
// u have to read the serial as well when loop is working it is not going to serial.read() so u have to call that fucntion in
digitalWrite(led_pin, HIGH); //in here and then just increase the value of x and condition will be false
delay(400);
delay(100);
Serial.println(x);
x=11;
Please use code tags when positing code. Click on the # button in the editor toolbar.
Also, please use CTRL+T inside the arduino IDE before copy-n-pasting code. It makes the code easier to read.
You still use delay()s inside you sketch, so you either didn't read blink without delay or there's something about it you don't understand. Feel free to ask.
I almost forgot about this. Here's the code I knocked out for it. I did have it using multiple if statements as you had before but just had to change that to a switch. This could likely be streamlined more, there are a couple of things that might be a bit redundant.
byte led_pin = 13; // led pin
boolean ledOn = false; // led state
boolean blinkOn = false; // blinking state
byte blinkCount = 0; // blink counter
unsigned long blinkDuration = 1000; // blink duration millis
unsigned long toggleTimer = 0; // for timing blinks
boolean powerOn = false; // our machines state
// Set up stuff
byte incoming_byte = 0; // clear storage for serial read
if (Serial.available() > 0) incoming_byte = Serial.read(); // read serial if available
switch (incoming_byte) // act on input
case 72: // H turns it on
if (!powerOn) // only turn on if needed
powerOn = true; // set power flag
Serial.println("Power is On.");
case 76: // L turns power off
if (powerOn) // only turn off if needed
powerOn = false; // clear power flag
blinkOn = false; // turn off blink
if (ledOn) toggleLed(); // turn off led if needed
Serial.println("Power is Off.");
case 65: // A starts the blinking
if (powerOn) // we can only blink if machine is on
blinkOn = true; // set blink flag
blinkCount = 0; // clear counter
toggleTimer = blinkDuration + millis(); // set timer for blink length
// DO the LED stuff
if (blinkOn && millis() > toggleTimer) // check if we should blink
toggleLed(); // switches led state
toggleTimer = blinkDuration + millis(); // set timer for next blink length
if (++blinkCount == 21) // stop after ten whole blinks
blinkOn = false; // turn blink off
if (ledOn) toggleLed(); // be sure led is off
void toggleLed(){
if (ledOn) // LED is on
digitalWrite(led_pin, LOW); // so turn it off
ledOn = false; // clear flag
else // otherwise its off
digitalWrite(led_pin, HIGH); // turn it on
ledOn = true; // set the flag
Correct.
Also, it isn't necessary to initialise "incoming_byte" when you declare it, if you make the switch part of the "available" condition, and then the declaration can go inside the condition too, which makes for a more natural construct.
