Hi all,
So, the project I am working on is a dog food dispenser. I gather user input through an LCD screen and switches and then process that data, so it is dispensed at the time the user selected. I'm working on obtaining that data and if the current time matches with the time selected by the user, dispense the food. When an IR sensor detects something, close the lid. The issue I'm having is that I can't seem to break out of the dispensing loop. I want to break out of the loop once the IR sensor detects something, so the lid stays closed even if the dispensing time matches the current time.
Here is the code that I have:
void Dispense::Timer(Menu screen)
unsigned long currentTime = millis() / 1000; //start timer
int Hours = screen.getHour() + numberOfHours(currentTime); //update hours
int Minutes = screen.getMinute() + numberOfMinutes(currentTime); //update minutes
int Seconds = numberOfSeconds(currentTime);
for (int i = 0; i < 10; i++)
if (screen.getTimer(i, 0) != NULL) //if there is data in the array
if (screen.getTimer(i, 0) == Hours && screen.getTimer(i, 1) == Minutes) //if times match
digitalWrite(greenLed, HIGH);
digitalWrite(redLed, LOW);
servoMotor.write(0); //open lid
if(digitalRead(IRsensor) == 0) //if IR sensor detects
digitalWrite(greenLed, LOW);
digitalWrite(redLed, HIGH);
servoMotor.write(90); //close lid
printTimer(Hours);
printTimer(Minutes);
When the current time is equal to the dispensing time, the lid stays open regardless of if the IR sensor detected something previously. How can I make it so that it won't open if the IR sensor detected an object and stay closed?
make the state of the IR sensor part of your decision to open or not
if (digitalRead(IRsensor) == HIGH) //if IR sensor is okay
if (digitalRead(IRsensor) == 0) //if IR sensor detects
printTimer(Hours);
You could check the IR sensor first and not even THINK about opening the feeder unless the IR sensor reads HIGH:
if (digitalRead(IRsensor) == LOW) // if IR sensor detects
else // (digitalRead(IRsensor) == HIGH)
// See if it is one of the times to open the lid
break; // Already open so no need to check the other times.
printTimer(Hours);
gcjr:
there's always a goto, which in many cases makes the code very much clearer
Seriously? Don't use goto, use break, continue, return or in a system with exceptions, raise an exception.
The only place a goto is considered acceptable is when transliterating a state-transition diagram to
code - although often switch/case is perfectly able to handle this too.
Once people start playing with goto the result is spaghetti code than noone wants to deal with!
the example you give is a perfect fit for "return;"
blh64:
Hmmm, so I tried this, but still, I can't get to close the lid when the IR sensor detects something and stay closed afterward (even if the IR sensor is HIGH)
Quote from: ferchi1809 Sun Mar 21 2021 13:42:17 GMT-0400 (Eastern Daylight Time)Hmmm, so I tried this, but still, I can't get to close the lid when the IR sensor detects something and stay closed afterward (even if the IR sensor is HIGH)
Sounds like the hardware isn't doing what you think you are telling it to do. I recommend using Serial to report every change in the hardware. When you find the IR Sensor is reading LOW, write a message. When you find the IR Sensor is reading HIGH, write a message. When you call servo.write(), write a message. Make sure the IR Sensor is reporting what you expect it to. Make sure the servo is moving to where you told it to.
Serial.println("IRsensor reads LOW");
Serial.println("Servo moved to 90 (Closed)");
Serial.println("IRsensor reads HIGH");
Serial.print("Current time matches timer "); Serial.println(i);
Serial.println("Servo moved to 0 (Open)");
printTimer(Hours);
