Hi All,
The holy goal is to make a baseball score board, operated by an MIT app inventor app, which writes a score into a homepage database.
By opening a specific page only a comma separated string is presented.
The scoreboard will have a arduino with the GSM 2 shield, to download this string continuously and change the 7 segment displays.
The string now looks like : @64,0,25,9,2,3,2,5!
I’ve added the @ at the beginning to filter out the unwanted data and ended with a !.
I’m now at the point where I can download the string from my homepage.
The problem is, that it is printed character by character in the loop section but I need it as a string at a single moment
I’ve tested a sketch where I put in a comma separated string into the serial command line. This section is now commented.
The current sketch is attached and below:
// libraries
#include <GSM.h>
// PIN Number
#define PINNUMBER “1234”
// APN data
#define GPRS_APN “live.vodafone.com” // replace your GPRS APN
#define GPRS_LOGIN “vodafone” // replace with your GPRS login
#define GPRS_PASSWORD “vodafone” // replace with your GPRS password
// Variabelen
// attempt
String Junk = “x”; // Junk is before the character “@”
String Volgnr = “x”;
String Guest = “x”;
String Home = “x”;
String Inning = “x”;
String Strike = “x”;
String Balls = “x”;
String Outs = “x”;
String BattingTurns = “x”;
// initialize the library instance
GSMClient client;
GPRS gprs;
GSM gsmAccess;
// URL, path & port (for example: arduino.cc)
char server = “www.stingray75.nl”;
char path = “/Score8.php”;
int port = 80; // port 80 is the default for HTTP
// initialize serial communications and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// Serial.println(“Starting Arduino web client.”);
// connection state
boolean notConnected = true;
// After starting the modem with GSM.begin()
// attach the shield to the GPRS network with the APN, login and password
while (notConnected) {
if ((gsmAccess.begin(PINNUMBER) == GSM_READY) &
(gprs.attachGPRS(GPRS_APN, GPRS_LOGIN, GPRS_PASSWORD) == GPRS_READY)) {
notConnected = false;
Serial.println(“Not connected”);
Serial.println(“connecting…”);
// if you get a connection, report back via serial:
if (client.connect(server, port)) {
Serial.println(“connected”);
// Make a HTTP request:
client.print(“GET “);
client.print(path);
client.println(” HTTP/1.1”);
client.print("Host: ");
client.println(server);
client.println(“Connection: close”);
client.println();//
// if you didn’t get a connection to the server:
Serial.println(“connection failed”);
// Serial.println(“laatste regel van de setup”);
// if there are incoming bytes available
// from the server, read them and print them:
if (client.available()) {
char c = client.read();
Serial.print(c);
while(client.connected()== true){
Serial.println(“Client is available before string”);
String Junk = client.readStringUntil(’@’);
Serial.read();
String Volgnr = Serial.readStringUntil(’,’);
Serial.read(); //next character is comma, so skip it using this
String Guest = Serial.readStringUntil (’,’);
Serial.read();
String Home = Serial.readStringUntil(’,’);
Serial.read();
String Inning = Serial.readStringUntil(’,’);
Serial.read();
String Strike = Serial.readStringUntil(’,’);
Serial.read();
String Balls = Serial.readStringUntil(’,’);
Serial.read();
String Outs = Serial.readStringUntil(’,’);
Serial.read();
String BattingTurns = Serial.readStringUntil(’!’);
Serial.read();
if (!client.available() && !client.connected()) {
Serial.print ("Volgnr: ");
Serial.println(Volgnr);
Serial.print ("Guest: ");
Serial.println(Guest);
Serial.print ("Home: ");
Serial.println(Home);
Serial.print ("Inning: ");
Serial.println(Inning);
Serial.print ("Strike: ");
Serial.println(Strike);
Serial.print ("Balls: ");
Serial.println(Balls);
Serial.print ("Outs: ");
Serial.println(Outs);
Serial.print ("BattingTurns: ");
Serial.println(BattingTurns);
// if the server’s disconnected, stop the client:
Serial.println(“disconnecting.”);
client.stop();
// do nothing forevermore:
for (;
The output in the serial monitor is :
connecting…
connected
HTTP/1.1 200 OK
Server: nginx
Date: Sat, 05 Aug 2017 22:16:00 GMT
Content-Type: text/html; charset=UTF-8
Vary: Accept-Encoding
Vary: Accept-Encoding,User-Agent
Connection: close
@64,0,25,9,2,3,2,5!
disconnecting.
Does anyone have a suggestion?
Regards
Stephan
GSMShieldGetLoop_leesstring_forum.ino (3.69 KB)
