I need to make a delay of , for instance, 180ms with high accuracy. If I make a subroutine like this, how much micro second delay I have to subtract it? Thanks.
You can use timer library. It will be useful when you are trying to run call function exact time .
Else use MSTIMER liberay to get control over function.
If you have an Arduino with a ceramic resonator rather than a quartz crystal the
+/-0.3% accuracy of ceramic resonator itself will dwarf any fiddle factor in your
loop.
Having said that waiting for micros() is a reasonable approach - the largest source
of error is the jitter caused by the timer0 interrupt handler (assuming a perfect
crystal timebase).
