How to calculate time difference
Hello.
Just start to learn Arduino platform and get stuck on simple (or not so simple) question.
I have two arrays. Arrays are time got from RTC DS1307. Event start time is in first array, event end time in second.
How do I manage to calculate time spent between events?
Thanks in advance!
Alex
substract ?
z = y - x
10 - 2 = 8
It depends on what format you are storing the timestamps in.
subtract the arrays first write the code to store values in one array from DS iC and then at a later point in the program again store the time in the array and then subtract both.
Ok, maybe my question was unclear. Let’s say start time is 13:12:24, end time 14:01:24 arrays ia as follows:
t1[0]=24 t1[1]=12 t1[2]=13
t2[0]=24 t2[1]=01 t2[2]=14
if we substrast start time from stop time:
for (int i = 0, i < 3, i++) {
spent_time[i] = t2[i] - t1[i];
we got: spent_time[0] = 0 spent_time[1] = -11 and spent_time[2] = 01
but i need to get 00:49:00.
Alex
Convert both to seconds, do the subtraction, then convert back.
well I do something similar, but I use a minutecounter or secondcounter for storing times in that array
minutecounter = hour60+minute (1440 minutes per day)
secondcounter = minutecounter
60+second (86400 seconds per day)
( if you need full date you can use Unixtime )
Yes. If I was doing it, I’d just store a seconds value or a Unix/Epoch time.
was thinking about converting to unix epoch, but unsuccess to find formula for arduino platform :frowning:
Which library are you using for your RTC?
using DS1307 library from “phi-menu” http://liudr.wordpress.com/libraries/phi-menu/.
This would do?
int start = t1[2]*3600 + t1[1] * 60 + t1[0];
int stop = t2[2]*3600 + t2[1] * 60 + t2[0];
int delta = stop - start;
t3[0] = delta % 60;
delta /= 60; // Same as delta = delta / 60
t3[1] = delta % 60;
delta /= 60;
t3[2] = delta;
How to modify this to give a correct value if stop is after midnight is left to do :wink:
karl_b, thanks a lot. but stop time can be after midnight. will try to figure out how to deal with it.
After some thought, you probably want to exchange those int:s to long:s, otherwise your code will only work for the first 8 hours in a day.
About the midnight problem, if your delta is always less than 24h you could try this:
if ( start > stop )
stop += 24*3600;
If you need longer delta than that you need to extend the function with calculation for days, months and/or years.
no need for longer time periods.
thanks a lot, problem solved.
Got strange behavior from calculating time using karl_b formula.
If time difference more than 1h and 10min, getting result with minus sign!
Let's say start time 08:00:00, stop time 09:15:00.
the result is -11:-9:-32 !!
I'm totally confused about this, since not so strong in math :frowning:
karl_b, pls help!
is Karl's array the other way around from yours ?
Check those first
the code is HOURS3600+MINUTES60+SECONDS
or Time[0]*3600+time[1]*60+time[2]
when the array is { HOURS, MINUTS, SECONDS }
check the Numbers !
int t1[]={0,0,0,0,0,0,0,};//sec - min - hour - and so on
int t2[]={0,0,0,0,0,0,0,};
int t3[]={0,0,0,0,0,0,0,};
in loop :
long Start = t1[2]*3600 + t1[1]*60 +t1[0];
long Stop = t2[2]*3600 + t1[1]*60 +t2[0];
long Delta = Stop - Start;    // Delta is now number of seconds between
int hours = Delta / 3600;    // HOURS
Delta = Delta - hours*3600 // removing full hours from teh difference
int minutes = Delta / 60;   // MINUTES
Delta = Delta - minutes *60; // removing full minutes
int seconds = Delta;         // SECONDS
t3[2] = hours;
t3[1] = minutes;
t3[0] = seconds;
this could be smaller I guess, but I think its easier to understand ?
my code now (assumes start at 8:00:00, finish at 9:15:00, variables declared of course):
m_starts[2] = 8;
m_starts[1] = 0;
m_starts[0] = 0;
m_finish[2] = 9;
m_finish[1] = 15;
m_finish[0] = 0;
long start = m_starts[2]*3600 + m_starts[1] * 60 + m_starts[0];
long finish = m_finish[2]*3600 + m_finish[1] * 60 + m_finish[0];
 long Delta = finish - start;
 Delta = Delta - hours * 3600;
 Delta = Delta - minutes * 60;
    last_laiks[0] = seconds;
    last_laiks[1] = minutes;
    last_laiks[2] = hours;
sprintf(msg,"%02d:%02d:%02d", last_laiks[2], last_laiks[1], last_laiks[0]);
    lcd.print(msg);
message printed: -16:-1149:-32 :frowning:
Strangines is, vhen i change m_finish[1] = 1; (09:01:00), i will get correct answer!!!
