Dear All,
How to write that V = -sqrt{(2 * (Pd /1000)) / 1.225} to the arduino program.
Dear All,
V = -sqrt((2. * Pd /1000.) / 1.225);
Which is the same as
V = -sqrt(Pd*1.633E-3);
jremington:
I use your code to the program, but it wrong output.
There may be some mistake. I rewrite that show you.
the calculation is √{(2 * (Pd /1000)) / 1.225}
How do you know?
Is there a minus sign "-" or not?
the original formula is V= √{(2 * (Pd /1000)) / 1.225}
shanelle:
- sqrt = √ ?
In math and C++, a leading minus sign indicates a negative value.
Without the minus sign, the formula is
V = sqrt(Pd*1.633E-3);
You need to declare V as float.
In the sticky thread, point 13, there's a link to the AVR libc docs. sqrt() in in the docs for math.h.
like this?
Serial.print("Start ");
Serial.println(__FILE__);
for (float Pd = 0; Pd < 10; Pd = Pd + 0.01)
float val = 2.0 * (Pd / 1000.0) / 1.225;
float v = sqrt( val );
Serial.print(Pd);
Serial.print("\t");
Serial.println(v);
