How to calibrate adafruit icm 20649
i did not find any documentation how to do it. Motioncal does not work
I moved your topic to an appropriate forum category @vmgm2.
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Hth
You probably don't need to calibrate the accelerometer. The modern ones are reasonably accurate "out of the box". To test the calibration, hold the sensor still with any axis vertical, and the reading along that axis will correspond +1 g or -1 g, depending on whether it is pointing up or down.
Calibrating the gyro is very simple. On startup, collect a few hundred X, Y and Z gyro readings while the sensor motionless, add them up and calculate the averages, which are good estimates of the zero offsets. Subtract the zero offsets from subsequent readings.
Thank you very much Indeed!
