How to call a unsigned char array with a function?
Hello,
I have different unsigned char arrays, e.g.
unsigned char PROGMEM mybigbitmap5[1][240] = {
  { 0x00, 0x00, 0x00, 0xff, 0x07,..
I can call them directly like this:
dots = pgm_read_byte_near(&(mybigbitmap5[c][cc]));
But I want to have a function where I call the name of the unsigned char array with other parameters and the array will be read, like this:
void putbigbitmap(byte x, byte y, unsigned char c, unsigned char *bitmapname, byte columncountbitmap, byte rowcountbitmap, char oddeven)
dots = pgm_read_byte_near(&(bitmapname[c][cc]));
and in the loop section I would call the unsigned char array
putbigbitmap(0, 0, 0,mybigbitmap5 , 40, 48, "G");
How could I call the different arrays?
Thanks in advance for any help.
That's not a call. That's a reference. It is passing a memory location to a function.
You don't pass the name of the array to a function. You pass the address of the array to the function.
If you are trying to pass mybigbitmap5 to putbigbitmap, the types need to match, including all qualifiers. mybigbitmap5 is a 2D array, or a char **, not a 1D array or char *.
