How to call the previous value into a new value in a separate loop?
2022-01-13T16:00:00Z
int pb = 0;
bool dipencet = 0 ;
int lag = 500;
int digit, i, j;
#define A  A5
#define B  A4
#define C  A3
#define D  A2
#define E  A1
#define F  A0
  pinMode(pb, INPUT_PULLUP); //digitalWrite(pb,HIGH);
  pinMode(A, OUTPUT);
  pinMode(B, OUTPUT);
  pinMode(C, OUTPUT);
  pinMode(D, OUTPUT);
  pinMode(E, OUTPUT);
  pinMode(F, OUTPUT);
  for (digit = 1 ; digit < 9; digit++)
    pinMode(digit, OUTPUT);
  digitalWrite(A, LOW);
  digitalWrite(B, HIGH);
  digitalWrite(C, HIGH);
  digitalWrite(D, LOW);
  digitalWrite(E, LOW);
  digitalWrite(F, LOW);
  for (digit = 1; digit < 9 ; digit++) {
    digitalWrite(digit, HIGH);
    delay(lag);
    digitalWrite(digit, LOW);
  digit = i;
  if (digitalRead(pb) == dipencet) {
    for (i = digit; i> 0 ; i--) {
      digitalWrite(i, HIGH);
      delay(lag);
      digitalWrite(i, LOW);
the initial value is the digits run to the right, if I press the push button then the digits will run to the left, if pressed again then the digits will return to the initial value, and if I press it for a long time then the digits will run to the right and left moving only at 1 digit
so just like this, please help
int pb = 0;
bool dipencet = 0 ;
int lag = 500;
int digit,i,j;
int count = 0;
bool mode = false;
#define A  A5
#define B  A4
#define C  A3
#define D  A2
#define E  A1
#define F  A0
pinMode(pb,INPUT_PULLUP); //digitalWrite(pb,HIGH);
pinMode(A,OUTPUT);
pinMode(B,OUTPUT);
pinMode(C,OUTPUT);
pinMode(D,OUTPUT);
pinMode(E,OUTPUT);
pinMode(F,OUTPUT);
for (digit= 1 ; digit<9; digit++)
pinMode(digit,OUTPUT);
digitalWrite(A,LOW);
digitalWrite(B,HIGH);
digitalWrite(C,HIGH);
digitalWrite(D,LOW);
digitalWrite(E,LOW);
digitalWrite(F,LOW);
for(digit = 1; digit < 9 ; digit++)
  if(digitalRead(pb) == dipencet )
    for(i = digit; i > 0 ; i--)
        if(digitalRead(pb) == dipencet){
          for(j = i; j<9 ; j++){
            digitalWrite(j,HIGH);
            delay(lag);
            digitalWrite(j,LOW);
            while(j ==8){
              j = 0;
            count = 0;
            mode = false;
      digitalWrite(i,HIGH);
      delay(lag);
      digitalWrite(i,LOW);
      while(i == 1)
          i = 9;
    count = 1;
    mode = true;
  digitalWrite(digit,HIGH);
  delay(lag);
  digitalWrite(digit,LOW);
it's 7 segment 8 digits
i didn't need 'G'
