How to call void inside void loop
HI Hello everyone
I think here something is missing ?? :confused:
#include "LiquidCrystal.h"
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
const int switch1 = 6;
const int switch2 = 7;
const int switch3 = 8;
const int led1 = 9;
const int led2 = 10;
const int led3 = 13;
void setup(){
  lcd.begin(16, 2);
pinMode(switch1,INPUT_PULLUP);
pinMode(switch2,INPUT_PULLUP);
pinMode(switch3,INPUT_PULLUP);
pinMode(led1,OUTPUT);
pinMode(led2,OUTPUT);
pinMode(led3,OUTPUT);
digitalWrite(led1,HIGH);
digitalWrite(led2,HIGH);
digitalWrite(led3,HIGH);
void loop(){
  lcd.setCursor(0, 0);
  lcd.print("ready");
  if(digitalRead(switch1 =LOW)){
doorPin();
  if(digitalRead(switch2 =LOW)){
windowPin();
  if(digitalRead(switch3 =LOW)){
lightPin();
void doorPin(){
  lcd.clear();
  lcd.print("door open");
digitalWrite(led,LOW);
delay(1000)
digitalWrite(led,HIGH);
delay(1500)
void windowPin(){
  lcd.clear();
  lcd.print("window open");
delay(500)
delay(1500)
void lightPin(){
  lcd.clear();
  lcd.print("light open");
delay(500)
delay(1500)
if(digitalRead(switch1 =LOW)){Oops.
That, plus missing braces.
Oops on top of an oops on top of an oops.
You don’t want to read PIN number (switch1 = LOW). You want to read PIN number switch1 and then compare that result to LOW. Check your parenthesis.
Also = is an assignment. For comparison you’d use ==
Also you’re missing the closing brace on loop so your functions (they’re called functions not voids, void is just the return type you happened to choose) are defined inside the loop function. You can’t define a function inside a function.
Go look at some examples and compare to your code.
As AWOL points out, you have missing braces.
If you use autoformat inside the editor, it makes it much easier to find mismatch braces.
CTRL-T on a PC autoformats.
LOGANTN:
What is missing is a description of your problem. Does it not compile? Does it do something you don't expect it to do? We are not mind readers, we don't know what you want your project to do. Only you know that.
Also, here is the reference for digitalRead().
This line
should be
if(digitalRead(switch1) == LOW){
and it is because that line is wrong that the call to doorPin() does not work
...R
HI , thank you for your answer
here new message and i can't call void
someone tells me the thing is i missed please
Arduino : 1.8.8 (Windows 7), Carte : "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Users\RAC\Documents\Arduino\sketch_feb01c\sketch_feb01c.ino: In function 'void loop()':
sketch_feb01c:33:9: error: 'doorPin' was not declared in this scope
 doorPin();
sketch_feb01c:36:11: error: 'windowPin' was not declared in this scope
 windowPin();
sketch_feb01c:39:10: error: 'lightPin' was not declared in this scope
 lightPin();
sketch_feb01c:42:15: error: a function-definition is not allowed here before '{' token
 void doorPin(){
sketch_feb01c:53:17: error: a function-definition is not allowed here before '{' token
 void windowPin(){
sketch_feb01c:64:16: error: a function-definition is not allowed here before '{' token
 void lightPin(){
sketch_feb01c:73:1: error: expected '}' at end of input
exit status 1
Ce rapport pourrait être plus détaillé avec
l'option "Afficher les résultats détaillés de la compilation"
activée dans Fichier -> Préférences.
We can't see your code.
Sorry
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
const int led1 = 9;
void setup(){
  lcd.begin();
  lcd.backlight();
void loop(){
  lcd.print("ready");
  if(digitalRead(switch1 == LOW)){
doorPin();
  if(digitalRead(switch2 == LOW)){
windowPin();
  if(digitalRead(switch3 == LOW)){
lightPin();
void doorPin(){
  lcd.clear();
delay(1000)
delay(1500)
void windowPin(){
  lcd.clear();
delay(500)
delay(1500)
void lightPin(){
  lcd.clear();
delay(500)
delay(1500)
You are missing a } to close your loop before you declare the doorPin function.
LightuC:
i close the loop }
and this is happen again
#include <Wire.h>
const int led1 = 9;
void setup(){
  lcd.begin();
  lcd.backlight();
void loop(){
  lcd.print("ready");
dooropen();
windowopen();
lightPin();
void dooropen(){
  lcd.clear();
delay(1000)
delay(1500)
void windowopen(){
  lcd.clear();
delay(500)
delay(1500)
void lightPin(){
  lcd.clear();
delay(500)
delay(1500)
sketch_feb01c:33:10: error: 'dooropen' was not declared in this scope
 dooropen();
sketch_feb01c:36:12: error: 'windowopen' was not declared in this scope
 windowopen();
 lightPin();
sketch_feb01c:42:16: error: a function-definition is not allowed here before '{' token
 void dooropen(){
sketch_feb01c:53:18: error: a function-definition is not allowed here before '{' token
 void windowopen(){
 void lightPin(){
exit status 1
You're trying to define all your functions inside of the loop function. You can't do that. Type ctrl-t in the IDE and note how things line up.
BTW, Please stop calling them "voids" they are NOT "voids". They are FUNCTIONS!
