how to capture multiple coordinate datas in an array
Hi, I am currently working on a project of micromanipulator using 3 stepper motors. One of the functions of the machine is to record the route of the movement and to shuttle between two working coordinates following the route I designated. I want to have a two dimentional array to store the sets of coordinates between the two working coordinates, i.e. (x0, y0, z0, 0), (x1,y1,z1,1)… (xn,yn,zn,n), if the routes takes n steps. What I want to do is to set the step number as n, using an interrupt funtion to record the coordinates coresponding to each step once the interrupt pin is triggered:
The program that I imagined looks something like this:
int n = 0;
int coordinates[n][4]
coordinate_record()
coordinates[4][n] = {x,y,z,n}
n++
In this way, I want to generate an n row, 4 column two dimentional array that store the route. However, I find it is not easy to manipulate array in C++ than doing so in python. I watched the tutorials on youtube on manipulation of arrays but found out that to populate arrays, there are two ways:
either you can populate an empty array all in once, like:
coordinates[5][4] = {{5,7,9,0},{1,3,5,1},{2,4,7,2},{5,8,1,3}}
or to use the for loop to read in each element one by one like this:
int coordintates[5][4]
for(int i=0; i<5; i++){
for(int j=0; j<4; j++){
coordinates*[j] = values*
I want to read in the coordinate of each step one by one to make the two dimentional array shown above, like:
coordinates[0][4] = {5,7,9,0};
coordinates[1][4] = {1,3,5,1};
coordinates[2][4] = {2,4,7,2};
coordinates[3][4] = {5,8,1,3};
Could anyone help me to solve the problem? Thank you.
Would it simplify things to create a struct for a single measurement and then have an array of structs - something like
struct PositionStruct {
   byte xVal;
   byte yVal;
   byte zVal;
PositionStruct arrayOfPositions[10];
Then you can refer to an individual value with
arrayOfPositions[n].xVal = 123;
...R
Hi Robin, thank you so much for your suggestions. I also got suggestions from others that I should use struct. So I will do some homework for this. :slight_smile:
Robin2:
byte xVal;
  byte yVal;
  byte zVal;
...R
Hi Robin, I tried this method and find the definition is confined within a function. I wrote the following code:
#include <Arduino.h>
struct PositionStruct{
int xVal;
int yVal;
int zVal;
void setup(){
PositionStruct arrayofPositions[10];
arrayofPositions[0].xVal = 123;
arrayofPositions[0].yVal = 456;
arrayofPositions[0].zVal = 789;
arrayofPositions[1].xVal = 500;
arrayofPositions[1].yVal = 600;
arrayofPositions[1].zVal = 700;
arrayofPositions[2].xVal = 100;
arrayofPositions[2].yVal = 200;
arrayofPositions[2].zVal = 300;
printCoordinate();
void loop(){
void printCoordinate(){
for(int i = 0; i< 10; i++){
Serial.println(arrayofPositions*.xVal);*
_ Serial.println(arrayofPositions*.yVal);_
_ Serial.println(arrayofPositions.zVal);
The arduino IDE report:
Coordinate:25: error: ‘arrayofPositions’ was not declared in this scope
Serial.println(arrayofPositions.xVal);
exit status 1
‘arrayofPositions’ was not declared in this scope*
However, if I move the Serial.println staff in the void setup() function, it works fine(like the code I pasted below. So could you tell me what is the problem?
* int xVal;
int yVal;
int zVal;
void setup(){
Serial.println(arrayofPositions.yVal);
void loop(){
}*_
This
should be
  Serial.println(arrayofPositions[i].xVal);
  Serial.println(arrayofPositions[i].yVal);
  Serial.println(arrayofPositions[i].zVal);
And see how there are no italics when you use the code tag </> to display code
...R
