I would like to employ the μCurrent gold to a system I am working on to make accurate current measurements with an external ADC and Atmega2560. However, I have a problem that the μCurrent gold doesn't have a protection against overcurrent or overvoltage.
I need the Ammeter to be able to measure in two ranges: ±199.9uA and ±1.999A current measurement with ±0.5% or better accuracy.
Preferably capable of AC and DC measurements similar to the μCurrent gold.
Is there a way to add a protection mechanism to the μCurrent gold?
Or am I better off using current sense amplifier or an instrumentation amplifier?, if so how do I protect them of several amps overcurrent or around 30V voltage?
Thank you, the links for the μCurrent gold were added..
I am just making a testing diy board to carry accurate measurements for some electronic circuits, and there could be instances where I mistakenly input higher currents than the range available..
Think I would use an AD1115 to measure the output of the AD8418. This is a16 bit ADC so given assuming 3 bits of noise you still have 8191 values in the range 0..5V is better than a millivolt per step.
Update: In fact it is a 15 bit ADC (thanks to wawa for pointing out)
As always the proof is building a prototype to see the actual range possible.
Overloads Fuses have been omitted from the design to ensure as low a total burden voltage as possible. Therefore you must be careful to ensure that the input is not connected directly across a supply voltage capable of providing a current that exceeds the selected range. Failure to take care here can result in a blown shunt resistor.
Not to mention there's actually no fuse to my knowledge that is available for such low current range..
Perhaps I should use two separate circuits for each of the two ranges, and switch between them. Then maybe use clamping diodes for the 200uA circuit?.
I don't think the AD8418 will be able to cover the range of 0-200uA, because with 1kOhm shunt and 1uA current the voltage will be 1mV, but with 200uA, the voltage will be 4V..
You could implement an active clamp using components like MOSFETs, SCRs, BJTs, etc. However, you must be extremely cautious about leakage current, especially with anything that has electrical contact with your leads, as it could affect the measurement.
For additional guidance, consider reviewing schematics of commercial units designed to measure your secret device.
