How to cast Hex-String to uint64_t ?
How can I cast a String of a hexnumber to an uint64_t ?
tobic:
You can't.
You need to convert the ASCII representation to binary, and this cannot be done with a cast.
There must be plenty of code available to do this, but a word of warning - use strings, not Strings.
Here a starter for the function you need, the commented line needs to be expanded
to include ABCDEF and optionally abcdef
uint64_t convertStringToU64(String str)   // char * preferred
  char t[16] = "0123456789ABCDEF";
  uint64_t val = 0;
  for (int i = 0; i < str.length(); i++)
    val = val * 16;
    val = val + str[i] - '0';  // convert char to numeric value << this line needs to be expanded to include ABCDEF
  return val;
you can test this code by using a string like “314159265”
Check this method:
uint64_t stringToUint_64(String value) {
int stringLenght = value.length();
uint64_t uint64Value = 0x0;
for(int i = 0; i<=stringLenght-1; i++) {
char charValue = value.charAt(i);
uint64Value = 0x10 * uint64Value;
uint64Value += stringToHexInt(charValue);
return uint64Value;
int stringToHexInt(char value) {
switch(value) {
case ‘0’:
return 0;
case ‘1’:
return 0x1;
case ‘2’:
return 0x2;
case ‘3’:
return 0x3;
case ‘4’:
return 0x4;
case ‘5’:
return 0x5;
case ‘6’:
return 0x6;
case ‘7’:
return 0x7;
case ‘8’:
return 0x8;
case ‘9’:
return 0x9;
case ‘A’:
case ‘a’:
return 0xA;
case ‘B’:
case ‘b’:
return 0xB;
case ‘C’:
case ‘c’:
return 0xC;
case ‘D’:
case ‘d’:
return 0xD;
case ‘E’:
case ‘e’:
return 0xE;
case ‘F’:
case ‘f’:
return 0xF;
:o
uint64_t stringToBinary (String hexString)
  return stringToBinary (hexString.c_str ());
uint64_t stringToBinary (const char* hexString)
  int length = min (16, strlen (hexString));
  uint64_t returnValue = 0;
  for (int i = 0; i < length && isxdigit (hexString[i]); ++i) {
    char digit = toupper (hexString [i]);
    returnValue *= 16;
    returnValue += (digit >= '0' && digit <= '9') ? digit - '0' : digit - 'A' + 10;
  return returnValue;
(compiled, but not fully tested)
You could try
uint64_t n;
char s[] = "F3B3D6";
sscanf(s, "%lx", &n);
