like the topic mention....
int[10] msg;
msg[0] = 1;
msg[1] = 2;
const char* a = (const char*)msg[0];
const char* b = (const char*)msg[1];
It seem there is no value when I test by printf
int[10] msg;
msg[0] = 1;
msg[1] = 2;
There is no value, or the value is zero?
What are you trying to do?
Do you know what data is at addresses 1 and 2?
I agree with AWOL. Also, even if it did work, it seems like you're trying to print the ASCII value for 0 and 1, which are non-printing. Maybe this will help you see what's going on:
int msg[10] ;
msg[0] = 65; // ASCII for 'A'
msg[1] = 66; // 'B'
const char* a = (char *) &msg[0];
const char* b = (char *) &msg[1];
Serial.println(a);
Serial.println(b);
Also, the statement
int[10] msg;
is not a proper definition in C.
I see ... so I don't that the 1 is ascii value . Now how can I conver int 1 to "1" please advice
econjack:
I agree with AWOL. Also, even if it did work, it seems like you're trying to print the ASCII value for 0 and 1, which are non-printing. Maybe this will help you see what's going on:void setup() {
int msg[10] ;
msg[1] = 66; // 'B'
const char* a = (char ) &msg[0];
const char b = (char *) &msg[1];
Serial.println(a);
Serial.println(b);
Also, the statement
int[10] msg;
I got a solution
char a[5];
sprintf(a, "%d", msg[0]);
char b[5];
sprintf(b, "%d", msg[1]);
char test[20];
strcpy(test, a);
strcat(test, ",");
strcat(test, b);
strcat(test, "\0");
mclient.publish("topic1/sensorAck",test);
If you're going to use sprintf, cut it down
char test[20];
sprintf(test, "%d,%d", msg[0], msg [1]);
Edit: sprintf_P would be even better.
Oh thank mann
