How to change a variable inside a class, in a library
Hello.
I am attempting to make a Arduino library. I don't find what I'm looking for in any tutorial I've seen yet.
Inside the library is one class. I want that class to have a variable, which i can change from outside the class. How is this done?
.h
#ifndef Hastighet_h
#define Hastighet_h
#include "Arduino.h"
class Hastighet :
  public:
    static int CHANGE_ME ;
#endif
.cpp
#include "Hastighet.h"
Hastighet::Hastighet()
CHANGE_ME //this is the variable I'd like to change, preferable from the main sketch.
Thank you for any response.
As it's static, you would be accessing it in a static context.
Hastighet.CHANGE_ME = 3;
A better way is to use what are called "getters" and "setters". No, they're not types of dog, but functions to get or change an internal class variable:
void Hastighet::setValue(int v) {
  CHANGE_ME = v;
int Hastighet::getValue() {
  return CHANGE_ME;
Hastighet myHast;
myHash.setValue(3);
... for example.
Also, as it's static, you may want
static int Hastighet::CHANGE_ME = 0;
in your .cpp to actually create the variable.
majenko: As it's static, you would be accessing it in a static context.
  CHANGE_ME = v;
int Hastighet::getValue() {   return CHANGE_ME; }
Hastighet myHast;
myHash.setValue(3);
... for example.
static int Hastighet::CHANGE_ME = 0; ```
Thank you, majenko. I've experimented a bit now, thanks to you.
